error occurred in openfoam
Old   July 3, 2012, 06:24
Default error occurred in openfoam
student
cd.pmd is on a distinguished road
When I import mesh in openform and change U and P after run in icofoam during run after some steps it generate error that error is :....................
DILUPBiCG: Solving for Uy, Initial residual = 0.994145, Final residual = 3.8729, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.994948, Final residual = 46610.1, No Iterations 1001
DICPCG: Solving for p, Initial residual = 1, Final residual = 3.29213, No Iterations 1001
time step continuity errors : sum local = 3.53548e+105, global = 1.49966e+88, cumulative = 1.49966e+88
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/icoFoam"
#7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Floating point exception
cd.pmd is offline   Reply With Quote
Old   July 3, 2012, 06:47
mehul
mehul.074 is on a distinguished road
when i import mesh in openform and change U and P after run in icofoam during run after some step it generate error that error is :....................
#0 Foam::error:: printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe:sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
happy@ubuntu:~/OpenFOAM/happy-2.0.1/run/testtutorials/incompressible/icoFoam/testcavity$ paraFoam
created temporary 'testcavity.OpenFOAM'
mehul.074 is offline   Reply With Quote
Old   July 3, 2012, 06:57
Retired Super Moderator
Bruno Santos
Greetings to both of you.
I've merged your two threads since you're basically asking the very same question... 23 minutes apart.
The answer is simple - go read the cavity tutorial once again, starting from this section: 2.1.5 Increasing the mesh resolution
And keep reading the rest of the tutorial until you understand what needs to be modified
Best regards,
Bruno
Old   September 28, 2014, 09:16
Jacky
bharat.cmeri is on a distinguished road
Best regards,
Bruno
can you please pin point what needs to be modified.
Thanks & Regards,
Bharat
bharat.cmeri is offline   Reply With Quote
Old   September 28, 2014, 09:24
Bruno Santos
Quick answer: Please read subsection "2.1.5.4 Control adjustments" on the OpenFOAM User Guide: http://www.openfoam.org/docs/user/cavity.php
Old   September 28, 2014, 11:23
Jacky
Thanks for your quick reply....
Regards,
Bharat
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 09:41
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 13:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 08:14
