p residual doesn't come down with QUICK scheme in simplefoam |
June 24, 2012, 09:51 |
Mostafa Moghaddami
Rep Power: 17 |
Dear All,
I have developed a solver based on the simplefoam solver. I have not changed anything in momentum solving, just I have added some transport equations to it. When I use UPWIND scheme for div(phi, U) the residuals comes down to 1e-7. Since the UPWIND scheme has some numerical diffusion I couldn't get the size of re-circulation zone correctly. So I decided to switch to the QUICK scheme for div(phi,U). After this change the re-circulation zone becomes larger (similar to what I expect), but after the re-circulation zone some unusual vortexes appears and the residual of the p does not comes smaller than 0.01. The fluid is water, flow is laminar and the nu is about 1e-6. Any helps would be appreciated. Regards |
p residual, quick, simplefoam convergence |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 13:53 |
