temperature gradient driven cavity flow.... OpenFOAM |
N Agrawal
Rep Power: 14 ![]() |
I am relatively new to openFOAM. I Want to setup a test case... temperature gradient driven cavity flow. I am confused as to which solver to be used. Is chtMultiRegionFoam a good choice to simulate this problem? Also how to go about setting up this case? Are there any tutorials available? I couldn't find any on my own. Any help would really be appreciated. |
Anton Kidess
Rep Power: 30 ![]() |
Use buoyantBoussinesqSimpleFoam and set boundary conditions accordingly.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
#3 | |
Srivathsan N
Rep Power: 13 ![]() |
I am trying the same too. Have you been successful in implementing it? I know its an old thread but it shall be really helpful if you reply.
Regards, Srivaths |
#4 | |
All you have got to do is to use cavity mesh and set correct boundary conditions. If you are not able to setup one, give me some more detailed information to help you setup your case. Best, Mojtaba
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
Srivathsan N
Hi all,
I've modified the cavity case into a liquid bridge with free surfaces on top and the bottom and side walls. I want to observe buoyancy driven flow between the two free surfaces. I'm having doubts with the bc's for p_rgh and U for this modified case. What should be the correct bc's in these conditions? Thanks in advance!
Regards, Srivaths |
cavity flow, chtmultiregionfoam, openfoam 2.1 |
plz help:supersonic flow in shear driven cavity | rajaero86 | ANSYS | 0 | March 8, 2011 01:50 |
Wall correction for the temperature gradient | Hagen | OpenFOAM | 0 | March 7, 2011 20:04 |
Temperature Gradient at Wall | sven | OpenFOAM | 7 | November 1, 2010 17:25 |
temperature normal gradient on a boundary | Sandrine | Main CFD Forum | 2 | June 10, 2009 16:34 |
Turbulence model in flow driven by surface tension | Z. ZENG | Main CFD Forum | 7 | April 28, 1999 07:18 |
