Heat transfer simulation with low-Re modelling blowing up
Old   June 15, 2012, 18:55
Default Heat transfer simulation with low-Re modelling blowing up
Jubayer
Location: The University of Western Ontario, London, Ontario
cm_jubayer is on a distinguished road
I am simulating atmospheric boundary layer flow over an inclined plate with application to solar panels. I am looking into the heat transfer from the panel. At the domain inlet, I am using mean profiles of velocity, turbulent kinetic energy and specific dissipation rate of turbulence using SST k-omega turbulence model. At the outlet of the domain I am using fixed pressure of 0 Pa. Without low-Re mesh (y+ around 200), for getting pressures on the panel (for wind load estimation), simulations runs fine. However for the heat transfer simulations with y+<1, simulation is blowing up as the courant number gets bigger and bigger (even with time step size of 10^-9 s) although wind speed is low for the heat transfer case (5 m/s at 10m height whereas for the wind loading simulation I have used 25 m/s without no problem). I am using buoyantBoussinesqPimpleFoam solver for the heat transfer simulation. My fvSchemes for heat transfer looks like the following:
ddtSchemes
default Euler;
gradSchemes
default cellLimited leastSquares 1.0;
divSchemes
default none;
div(phi,U) Gauss vanLeer;
div(phi,T) Gauss vanLeer;
div(phi,k) Gauss vanLeer;
div(phi,omega) Gauss vanLeer ;
div(phi,R) Gauss vanLeer ;
div(R) Gauss limitedLinear 1 ;
div((nuEff*dev(T(grad(U))))) Gauss linear limited 0.5 ;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear limited 0.5;
laplacian((1|A(U)),p_rgh) Gauss linear limited 0.5 ;
laplacian(kappaEff,T) Gauss linear limited 0.5;
laplacian(DkEff,k) Gauss linear limited 0.5;
laplacian(DomegaEff,omega) Gauss linear limited 0.5;
laplacian(DREff,R) Gauss linear limited 0.5;
interpolationSchemes
default linear;
snGradSchemes
default limited 0.5;
fluxRequired
default no;
p_rgh ;
Below is a glimpse when simulation is blowing up
Time = 0.00010097
Courant Number mean: 4.7345636e-07 max: 1233.7809
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 1.2870124e-06, Final residual = 7.1891992e-09, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.76361335, Final residual = 0.00097027484, No Iterations 120
time step continuity errors : sum local = 1.4489948e-10, global = 9.5209982e-12, cumulative = -6.5187104e-12
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 2.5226717e-06, Final residual = 8.3556918e-09, No Iterations 101
DICPCG: Solving for p_rgh, Initial residual = 0.69872336, Final residual = 0.00098344698, No Iterations 419
time step continuity errors : sum local = 4.5798547e-10, global = 1.8186047e-11, cumulative = 1.1667336e-11
DILUPBiCG: Solving for omega, Initial residual = 0.00050378054, Final residual = 5.0894516e-09, No Iterations 109
bounding omega, min: -1.6530455e+12 max: 3.8839584e+12 average: 59305422
DILUPBiCG: Solving for k, Initial residual = 0.00035940466, Final residual = 5.3762244e-09, No Iterations 99
bounding k, min: -8.6846115e+11 max: 2.7713031e+12 average: 1585310.7
ExecutionTime = 13894.57 s ClockTime = 13905 s
Time = 0.00010098
Courant Number mean: 6.9096584e-07 max: 2692.3661
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 3.1575455e-06, Final residual = 9.7394175e-09, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.74447529, Final residual = 0.00097299859, No Iterations 97
time step continuity errors : sum local = 2.4875275e-10, global = 1.7993474e-11, cumulative = 2.9660811e-11
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 3.7889403e-06, Final residual = 5.7741675e-09, No Iterations 153
DICPCG: Solving for p_rgh, Initial residual = 0.7661894, Final residual = 0.00099395397, No Iterations 444
time step continuity errors : sum local = 2.5940091e-09, global = 8.240833e-11, cumulative = 1.1206914e-10
DILUPBiCG: Solving for omega, Initial residual = 0.00087259239, Final residual = 8.3974792e-09, No Iterations 79
bounding omega, min: -7.5412548e+11 max: 1.9226682e+12 average: 94265063
DILUPBiCG: Solving for k, Initial residual = 0.0015909616, Final residual = 8.3691303e-09, No Iterations 68
bounding k, min: -3.2118556e+11 max: 2.0770441e+12 average: 4234488.5
ExecutionTime = 14445.9 s ClockTime = 14456 s
Time = 0.00010099
Courant Number mean: 1.9504303e-06 max: 5747.6202
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 1.6991088e-05, Final residual = 2.6964904e-09, No Iterations 4
DICPCG: Solving for p_rgh, Initial residual = 0.75607356, Final residual = 0.00099111414, No Iterations 201
time step continuity errors : sum local = 8.4048694e-10, global = 3.4520769e-10, cumulative = 4.5727683e-10
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 2.9118025e-05, Final residual = 7.2186118e-09, No Iterations 419
DICPCG: Solving for p_rgh, Initial residual = 0.84296989, Final residual = 0.00095307524, No Iterations 706
time step continuity errors : sum local = 4.7938114e-09, global = 1.1318495e-09, cumulative = 1.5891263e-09
DILUPBiCG: Solving for omega, Initial residual = 0.0067051264, Final residual = 7.1001411e-09, No Iterations 328
bounding omega, min: -1.4353841e+14 max: 1.3961573e+14 average: 1.7683567e+09
DILUPBiCG: Solving for k, Initial residual = 0.0091318156, Final residual = 9.0899654e-09, No Iterations 214
bounding k, min: -6.8698845e+11 max: 1.075334e+13 average: 19477433
ExecutionTime = 15914.84 s ClockTime = 15926 s
Time = 0.000101
Courant Number mean: 9.2903545e-06 max: 33446.887
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 3.5918305e-05, Final residual = 7.4009402e-09, No Iterations 3
DICPCG: Solving for p_rgh, Initial residual = 0.51530912, Final residual = 0.00098150633, No Iterations 87
time step continuity errors : sum local = 5.6978294e-09, global = 1.1952208e-09, cumulative = 2.7843471e-09
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 9.5350344e-05, Final residual = 6.6825388e-07, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 0.64166418, Final residual = 0.026321393, No Iterations 1001
time step continuity errors : sum local = 1.7760159e-06, global = 1.8077374e-09, cumulative = 4.5920845e-09
DILUPBiCG: Solving for omega, Initial residual = 0.02237984, Final residual = 6.0043179e-09, No Iterations 420
bounding omega, min: -4.1960305e+14 max: 2.2858488e+14 average: 7.0990082e+08
DILUPBiCG: Solving for k, Initial residual = 0.009506604, Final residual = 0.0018439062, No Iterations 1001
bounding k, min: -1.7533181e+15 max: 8.382294e+14 average: -3.8906711e+08
ExecutionTime = 19251.27 s ClockTime = 19265 s
Time = 0.00010101
Courant Number mean: 2.9411928e-05 max: 42822.926
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 0.011547178, Final residual = 4.2007322e-09, No Iterations 7
DICPCG: Solving for p_rgh, Initial residual = 0.5517749, Final residual = 0.00098472085, No Iterations 87
time step continuity errors : sum local = 1.9706388e-08, global = 1.9126112e-09, cumulative = 6.5046957e-09
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 0.00045584686, Final residual = 5.7580162e-07, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 0.79932465, Final residual = 0.21947454, No Iterations 1001
time step continuity errors : sum local = 4.5888733e-05, global = 2.4650819e-09, cumulative = 8.9697776e-09
DILUPBiCG: Solving for omega, Initial residual = 0.046824604, Final residual = 0.42651976, No Iterations 1001
bounding omega, min: -2.9120631e+16 max: 7.5610454e+15 average: -1.7510987e+10
DILUPBiCG: Solving for k, Initial residual = 0.10073936, Final residual = 0.053489969, No Iterations 1001
bounding k, min: -6.1933141e+14 max: 5.4698344e+14 average: -1.1146877e+09
ExecutionTime = 23333.7 s ClockTime = 23350 s
Time = 0.00010102
Courant Number mean: 0.00057248341 max: 283410.74
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 0.84933889, Final residual = 2.0178504e-09, No Iterations 9
DICPCG: Solving for p_rgh, Initial residual = 0.91110456, Final residual = 0.00098260631, No Iterations 202
time step continuity errors : sum local = 2.6226461e-07, global = -4.8494379e-08, cumulative = -3.9524602e-08
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 0.033386681, Final residual = 0.014155016, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 0.80383648, Final residual = 5.7958476, No Iterations 1001
time step continuity errors : sum local = 0.020399066, global = -9.6567685e-09, cumulative = -4.918137e-08
DILUPBiCG: Solving for omega, Initial residual = 0.98880096, Final residual = 11962.323, No Iterations 1001
bounding omega, min: -6.4680894e+24 max: 3.2921399e+25 average: 5.2212511e+19
DILUPBiCG: Solving for k, Initial residual = 0.014781795, Final residual = 3.0990057e-08, No Iterations 1001
bounding k, min: -4.8263648e+14 max: 5.4072665e+14 average: 1.0635891e+09
ExecutionTime = 27448.32 s ClockTime = 27467 s
Time = 0.00010103
Courant Number mean: 0.045544987 max: 5.2721582e+08
PIMPLE: iteration 1
DILUPBiCG: Solving for T, Initial residual = 0.49369191, Final residual = 7.5375708e-09, No Iterations 7
DICPCG: Solving for p_rgh, Initial residual = 0.96557631, Final residual = 0.00099907484, No Iterations 238
time step continuity errors : sum local = 3.3753698e-05, global = 7.2331754e-06, cumulative = 7.183994e-06
PIMPLE: iteration 2
DILUPBiCG: Solving for T, Initial residual = 0.88776239, Final residual = 50.198586, No Iterations 1001
DICPCG: Solving for p_rgh, Initial residual = 0.0023242099, Final residual = 1.4577883, No Iterations 1001
time step continuity errors : sum local = 171.529, global = 1.7893858e-06, cumulative = 8.9733799e-06
I'll be really glad if someone helps me dealing with this problem and getting my simulation running. Thanks.
Jubayer
cm_jubayer is offline   Reply With Quote
Old   June 19, 2012, 04:59
romant's Avatar
Roman Thiele
romant is on a distinguished road
Have you tried using different input for the divergence and laplacian schemes?
divergence as "Gauss upwind" and laplacian as "Gauss linear corrected", especially for the parts where you use k and omega. These schemes have worked for me with different simulations. If you really need to use the schemes that you have as an input now, I would start from these easier schemes and switch over to more advanced schemes step by step.
~roman
romant is offline   Reply With Quote
Old   June 19, 2012, 05:29
Olivier
olivierG is on a distinguished road
hello,
Your time step seems too big, since your Co number is getting higer and higer ...
Try to lower your time step, or use adaptative time stepping.
regards,
olivier
olivierG is offline   Reply With Quote
Old   June 19, 2012, 10:46
Jubayer
Hi Roman,
Thanks for your advice. I'll try those schemes. However, I used simpler schemes before, but did not work. Lets hope this time it works.
Jubayer
Old   June 19, 2012, 10:49
Jubayer
Hi Olivier,
I thought of the time step size at first. But as you can see, I have even used 10^-09 s for this full scale simulation, lowering time step size more than that does not make sense. This made me belief that the problem is somewhere else. Thanks for your input.
Jubayer
abl, blowing up, flat plate, heat transfer, low reynolds
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Multiphase flow and conjugate heat transfer simulation awacs OpenFOAM Running, Solving & CFD 8 March 1, 2013 06:25
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
About CFX11 low temperature for heat transfer karke CFX 6 July 30, 2007 22:10
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
