Continuity error cannot be removed by adjusting the outflow
Old   June 7, 2012, 02:12
Default Continuity error cannot be removed by adjusting the outflow
fontania is on a distinguished road
OpenFOAMers,
I have a case that receives this continuity error. I am running the application buoyantBoussinesqPimpleFoam. Turbulence is "on" and I am using the RNGkEpsilon RASModel. I don't think my case is overdefined, but I have added below my 0/p, 0/U, and 0/p_rgh files Any help would be appreciated.
Thank you in advance
[0]
[0] --> FOAM FATAL ERROR:
[0] Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 136228.04
Specified mass inflow : 296.39639
Specified mass outflow : 0
Adjustable mass outflow : 2.10095737e-12
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall_1
type zeroGradient;
inlet
type zeroGradient;
wall-ceiling
type zeroGradient;
wall-floor
type zeroGradient;
wall-side-1-1
type zeroGradient;
wall-side-1-2
type zeroGradient;
wall-side-2-2
type zeroGradient;
wall-side-2-1
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall-tube
type zeroGradient;
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
wall_1
type buoyantPressure;
rho rhok;
value uniform 0;
inlet
type zeroGradient;
wall-ceiling
rho rhok;
value uniform 0;
wall-floor
rho rhok;
value uniform 0;
wall-side-1-1
rho rhok;
value uniform 0;
wall-side-1-2
rho rhok;
value uniform 0;
wall-side-2-2
rho rhok;
value uniform 0;
wall-side-2-1
rho rhok;
value uniform 0;
outlet
type zeroGradient;
wall-tube
rho rhok;
value uniform 0;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall_1
type fixedValue;
value uniform (0 0 0);
inlet
type fixedValue;
value uniform (0 0 7.67482);
wall-ceiling
type fixedValue;
wall-floor
type fixedValue;
wall-side-1-1
type fixedValue;
wall-side-1-2
type fixedValue;
wall-side-2-2
type fixedValue;
wall-side-2-1
type fixedValue;
outlet
type zeroGradient;
wall-tube
type fixedValue;
fontania is offline   Reply With Quote
Old   October 9, 2012, 11:36
Paula
curiosity is on a distinguished road
Hi Fontania,
I´m not very sure about this but it´s a problem that I´ve had and I´ve solved it adjusting velocities. This is: v_inlet*A_inlet=v_outlet*A_outlet
If you know three of these parameters (areas and initial velocity) you can obtain the other one and put it on the inicial conditions to make the continuity ecuation works... but, I repeat, I´m not so sure about this, sorry
Regards
curiosity is offline   Reply With Quote
continuity error
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
