Wall treatment with OpenFOAM
Like Tree109Likes
Old   November 20, 2015, 04:13
KateEisenhower is on a distinguished road
Hello foamers,
As I understood from the source code, the omegaWallFunction is continuous and so can be used for a low-Re simulation as well. My boundary field in the omega dictionary looks as follows:
no_slip_wall
     type             omegaWallFunction;
     value            uniform ???;
     Cmu              0.09;
     kappa            0.41;
     E                9.8;
     beta1            0.075;
I am not sure what I should set as value. Is it reasonable to take the value I have calculated for my velocity inlet?
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   November 20, 2015, 04:16
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
As far as I know, "value" is only used for the very first iteration of the very first time step. So unless the solution does diverge, I think you can set any value you want. Since this is a wall, I would go for a very high value.
KateEisenhower and piu58 like this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 20, 2015, 04:43
akidess's Avatar
Anton Kidess
A possible guideline is
\omega_w = 6 \nu / (\beta * y^2)
I'm not sure if the standard kOmega model in OpenFoam is suitable for lowRe setups. Anyway, as Rodriguez said, it's just an initial guess, but why not make an educated one
See also: http://www.cfd-online.com/Wiki/Near-...k-omega_models
KateEisenhower likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 20, 2015, 04:45
Philipp
Anton, as you can see from the formula you posted, omega goes to infinity at the wall. So it will never be a good guess to set omega to zero, not for high-Re and not for low-Re. It's always pretty high, such as 1e8.
akidess likes this.
Old   November 20, 2015, 04:54
akidess's Avatar
Anton Kidess
Right, I mixed something up there. Fixed now, thanks!
Old   September 5, 2016, 06:41
Hello all,
can anyone confirm this? Is this also the case for other turbulent paramters at a wall?
Best regards,
Kate
Old   March 2, 2017, 08:38
Giuseppe
Giuseppe92 is on a distinguished road
I found this post very intersting and I would like to clarify something about the k-omega SST model in OpenFoam.
I have understood that if I want to use wall function I need a y+ between 30 and 100 for a good result. In order to do this I can write like this in 0/k file for a boundary:
liner
type kqRWallFunction;
value uniform 4e-07;
If I want to solve the boundary layer I need a y+<=1 first of all and not to call the wall function.
My question is: How can I manage k-omega SST without wall function for example on the above boundary for k?
Thank you in advance.
Best Regards,
Giuseppe
Giuseppe92 is offline   Reply With Quote
Old   July 21, 2018, 22:00
Cristina Hernandez
crizpi21 is on a distinguished road
Hi Giuseppe,
Did you find any answer to your question?
I am also interested in how to model the boundary layer using k-omega SST
(I am running a simulation of the flow past a bluff body), either using wall functions or directly solving the boundary layer.
Maybe it would also be helpful if you could share your case.
Thanks in advance
Cristina
crizpi21 is offline   Reply With Quote
Old   May 28, 2021, 12:38
Guanjiang Chen
guanjiang.chen is on a distinguished road
liner
Best Regards,
Giuseppe
I think the type should be fixedValue or calculated.
Noah Zhang likes this.
guanjiang.chen is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
Radiative equilibrium wall condition in OpenFOAM JLight OpenFOAM 0 September 12, 2011 00:31
Near Wall treatment sven OpenFOAM 1 September 13, 2009 21:57
Hybrid Wall Treatment in OpenFOAM cbarry OpenFOAM 1 August 27, 2009 05:02
