MRFSimpleFoam wind turbine case diverges
Old   May 22, 2012, 09:59
Default MRFSimpleFoam wind turbine case diverges
Seon Hye
ysh1227 is on a distinguished road
Hi, everyone.
I am new in OF(OF 2.1.0).
I try to run the Small Horizontal Axis Wind Turbine case using MRFSimpleFoam.
First, I simulated that case with the condition that is no rotation and no velocity, and the result is good and there is no problem. The continuity error is very very small that I expected.
However, the problem occured when I simulated that case with no rotation and 7m/s inlet-velocity. After about 30 iterations, the continuity error started to increase more than 1 and finally it became very very big. The results also was very wrong when I view the velocity and pressure fields using paraView due to bad continuity error.
I already tried to change the fvScheme and fvSolver and simulated a lot of cases with the same mesh file. but Always I failed to solve because of the same reason, 'time step continuity error'.
Before simulating this case, I had the AMI problems and resolved it by making a new mesh. So, there is no AMI problems in this case, I already checked it. And my final goal is to use pimpleDyMFoam as soon as possible.
Therefore, I need your help.
Now, I'm typing it with remote control to my computer in lab. so I couldn't show you the detail of my case. But I try to give you the details as mush as possible.
I want you to reply about
1. how I can reduce the continuity error
2. Whether the fvSchemes and fvSolution is proper or not
and 3. better ideas to solve this case.
[more informations about the best but failed case that I've solved]
the log file and files in '0' folder is attached.
1. output from the terminal near the problem
PHP Code:
Time 12
smoothSolver
:  Solving for UxInitial residual 0.24178, Final residual 4.66485e-09No Iterations 24
smoothSolver
:  Solving for UyInitial residual 0.236673, Final residual 8.17346e-09No Iterations 22
smoothSolver
:  Solving for UzInitial residual 0.232616, Final residual 5.05721e-09No Iterations 24
GAMG
:  Solving for pInitial residual 0.00439615, Final residual 4.39105e-06No Iterations 936
GAMG
:  Solving for pInitial residual 8.99011e-06, Final residual 9.74321e-07No Iterations 10
GAMG
:  Solving for pInitial residual 2.92193e-06, Final residual 9.18676e-07No Iterations 3
time step continuity errors
sum local 1.34624, global = 0.000523313cumulative 0.000717847
smoothSolver
:  Solving for omegaInitial residual 0.330051, Final residual 4.44257e-07No Iterations 8
smoothSolver
:  Solving for kInitial residual 0.0234427, Final residual 2.08236e-07No Iterations 10
ExecutionTime
11239.2 s  ClockTime 11277 s
Time
13
smoothSolver
:  Solving for UxInitial residual 0.394172, Final residual 9.36361e-09No Iterations 24
smoothSolver
:  Solving for UyInitial residual 0.236768, Final residual 2.40871e-09No Iterations 24
smoothSolver
:  Solving for UzInitial residual 0.355896, Final residual 9.66341e-09No Iterations 24
GAMG
:  Solving for pInitial residual 0.00107708, Final residual 2.64334e-06No Iterations 1000
GAMG
:  Solving for pInitial residual 3.54345e-05, Final residual 1.29183e-06No Iterations 1000
GAMG
:  Solving for pInitial residual 9.14944e-06, Final residual 9.99899e-07No Iterations 39
sum local 0.686033, global = 0.000218238cumulative 0.000936085
smoothSolver
:  Solving for omegaInitial residual 0.425149, Final residual 3.32176e-07No Iterations 12
smoothSolver
:  Solving for kInitial residual 0.0224997, Final residual 4.76061e-07No Iterations 8
ExecutionTime
12351.3 s  ClockTime 12392 s
Time
14
smoothSolver
:  Solving for UxInitial residual 0.195003, Final residual 2.3199e-09No Iterations 24
smoothSolver
:  Solving for UyInitial residual 0.173547, Final residual 9.25896e-09No Iterations 22
smoothSolver
:  Solving for UzInitial residual 0.19108, Final residual 2.86689e-09No Iterations 24
GAMG
:  Solving for pInitial residual 0.00154395, Final residual 1.54298e-06No Iterations 907
GAMG
:  Solving for pInitial residual 3.66792e-06, Final residual 8.65631e-07No Iterations 2
GAMG
:  Solving for pInitial residual 1.34099e-06, Final residual 7.70434e-07No Iterations 1
sum local 4.70061, global = -0.00500594cumulative = -0.00406985
smoothSolver
:  Solving for omegaInitial residual 0.333175, Final residual 5.88616e-07No Iterations 6
smoothSolver
:  Solving for kInitial residual 0.0389014, Final residual 2.82821e-07No Iterations 8
ExecutionTime
12859 s  ClockTime 12902 s
Time
15
smoothSolver
:  Solving for UxInitial residual 0.178065, Final residual 6.43032e-09No Iterations 22
smoothSolver
:  Solving for UyInitial residual 0.214259, Final residual 2.16551e-09No Iterations 24
smoothSolver
:  Solving for UzInitial residual 0.196981, Final residual 7.3701e-09No Iterations 22
GAMG
:  Solving for pInitial residual 0.000258065, Final residual 9.99113e-07No Iterations 917
GAMG
:  Solving for pInitial residual 3.00182e-07, Final residual 3.00182e-07No Iterations 0
GAMG
sum local 53.2202, global = -0.00137399cumulative = -0.00544385
smoothSolver
:  Solving for omegaInitial residual 0.333346, Final residual 3.29517e-07No Iterations 8
smoothSolver
:  Solving for kInitial residual 0.217336, Final residual 2.4148e-07No Iterations 12
ExecutionTime
13368.8 s  ClockTime 13413 s
Time
16
smoothSolver
:  Solving for UxInitial residual 0.33311, Final residual 2.71606e-09No Iterations 22
smoothSolver
:  Solving for UyInitial residual 0.278035, Final residual 9.89641e-09No Iterations 22
smoothSolver
:  Solving for UzInitial residual 0.299317, Final residual 3.8482e-09No Iterations 22
GAMG
:  Solving for pInitial residual 7.77667e-06, Final residual 9.36191e-07No Iterations 6
GAMG
:  Solving for pInitial residual 1.15861e-06, Final residual 9.26386e-07No Iterations 1
GAMG
:  Solving for pInitial residual 8.8794e-07, Final residual 8.8794e-07No Iterations 0
sum local 138.064, global = -0.143375cumulative = -0.148819
smoothSolver
:  Solving for omegaInitial residual 0.333087, Final residual 1.17684e-07No Iterations 6
smoothSolver
:  Solving for kInitial residual 0.0501571, Final residual 3.91316e-07No Iterations 12
ExecutionTime
13391.3 s  ClockTime 13436 s
Time
17
smoothSolver
:  Solving for UxInitial residual 0.167577, Final residual 2.71625e-09No Iterations 24
smoothSolver
:  Solving for UyInitial residual 0.132945, Final residual 3.52546e-09No Iterations 22
smoothSolver
:  Solving for UzInitial residual 0.154564, Final residual 2.4897e-09No Iterations 24
GAMG
:  Solving for pInitial residual 1.56889e-05, Final residual 8.79822e-07No Iterations 2
GAMG
:  Solving for pInitial residual 6.76478e-09, Final residual 6.76478e-09No Iterations 0
GAMG
sum local 427.601, global = -0.153837cumulative = -0.302656
smoothSolver
:  Solving for omegaInitial residual 0.333002, Final residual 6.87238e-07No Iterations 10
smoothSolver
:  Solving for kInitial residual 0.432678, Final residual 3.14185e-07No Iterations 10
ExecutionTime
13411.8 s  ClockTime 13456 s
2) structure of my case
I attached the file.
3) boundary
BLADEFIRST
type wall;
nFaces 28088;
startFace 32433504;
BLADESECOND
type wall;
nFaces 28088;
startFace 32461592;
HUB
type wall;
nFaces 8924;
startFace 32489680;
AMI_DISK_FRONT
type cyclicAMI;
nFaces 64812;
startFace 32498604;
matchTolerance 0.001;
neighbourPatch AMI_DOMAIN_FRONT;
transform noOrdering;
AMI_DISK_BACK
type cyclicAMI;
nFaces 64812;
startFace 32563416;
neighbourPatch AMI_DOMAIN_BACK;
AMI_DISK_SIDE
type cyclicAMI;
nFaces 40468;
startFace 32628228;
neighbourPatch AMI_DOMAIN_SIDE;
AMI_DOMAIN_FRONT
type cyclicAMI;
nFaces 29440;
startFace 32668696;
neighbourPatch AMI_DISK_FRONT;
AMI_DOMAIN_BACK
type cyclicAMI;
nFaces 19968;
startFace 32698136;
neighbourPatch AMI_DISK_BACK;
AMI_DOMAIN_SIDE
type cyclicAMI;
nFaces 11776;
startFace 32718104;
neighbourPatch AMI_DISK_SIDE;
INLET_VELOCITY
type patch;
nFaces 38656;
startFace 32729880;
OUTLE_PRESSURE
type patch;
nFaces 29184;
startFace 32768536;
SYMMETRY
type wall;
nFaces 41984;
startFace 32797720;
4) MRFZones
FLUID
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches (AMI_DISK_FRONT AMI_DISK_BACK AMI_DISK_SIDE AMI_DOMAIN_FRONT AMI_DOMAIN_BACK AMI_DOMAIN_SIDE);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 0;
5) fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
// default none;
// div(phi,U) Gauss limitedLinearV 1;
// div(phi,k) Gauss limitedLinear 1;
// div(phi,omega) Gauss limitedLinear 1;
// div((nuEff*dev(T(grad(U))))) Gauss linear;
default none;
div(phi,U) Gauss upwind;
div(phi,U) Gauss linearUpwind grad(U);
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
6) fvSolution
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.001;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 20;
agglomerator faceAreaPair;
mergeLevels 1;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-08;
relTol 0;
k
nSweeps 2;
tolerance 1e-06;
relTol 0;
omega
nSweeps 2;
tolerance 1e-06;
relTol 0;
SIMPLE
nNonOrthogonalCorrectors 2;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
p 0.3;
equations
U 0.5;
k 0.5;
omega 0.5;
ysh1227 is offline   Reply With Quote
Old   May 6, 2015, 10:51
M. Montero
be_inspired is on a distinguished road
Did you find the solution?
be_inspired is offline   Reply With Quote
Old   May 7, 2015, 11:13
Seon Hye
Unfortunately, I do not use openfoam anymore, so I have no idea about that question. Sorry.
Can I use Turbogrid to mesh a wind turbine blade? Henry Liu CFX 10 November 10, 2011 06:41
Pressure Drop/Porous Media within Shrouded Wind Turbine Simulation joshdsouza FLUENT 0 March 3, 2010 19:02
Usage of Star-CD in analysis of Wind Turbine Manabendra M. De Siemens 5 January 7, 2007 00:42
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Wind turbine simulation Saturn Main CFD Forum 1 June 12, 2006 04:57
