May 21, 2012, 05:48 |
AMI matchTolerance
Attesz
Rep Power: 17 |
i'm getting errors for an AMI fan simulation. At a given timestep, the weights of the AMI reaches 0. I saw that some guys here already faced this problem, but I couldn't find any clear suggestion to avoid it. To start to investigate this problem I try to understand the matchTolerance value in polymesh/boundary file. Can you explain me it's function? It's a geometrical tolerance for the two sides of the AMIs? In the case described above, should I increase or decrease it? |
ami, matchtolerance, weight |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
Problems using reconstructPar on a case involving AMI | Kaskade | OpenFOAM Running, Solving & CFD | 38 | September 30, 2020 06:36 |
OpenFOAM 2.1.x - AMI (Arbitrary Mesh Interface) | philippose | OpenFOAM Running, Solving & CFD | 39 | March 17, 2017 09:52 |
propeller tutorial using AMI in OF v2.1.0 | impecca | OpenFOAM Pre-Processing | 6 | May 9, 2016 10:22 |
Problem in AMI | ysh1227 | OpenFOAM Running, Solving & CFD | 9 | March 23, 2015 09:43 |
