reactingFoam RAS Turbulence Statistics
Old   May 10, 2012, 15:32
Default reactingFoam RAS Turbulence Statistics
L.Bryce Whitson Jr.
LWhitson2 is on a distinguished road
I am still a little new to OpenFOAM and am having a problem calculating some turbulence statistics. What I am interested in is the Mean and Standard Deviation of the scalar values of a 100ms simulation. In doing the calculation, I am using the k-e turbulence model and starting with an an already "converged" solution, ie it should be at steady state for the most part. The flow is of a reacting jet flowing into quescent air.
It was my understanding that reactingFoam is an unsteady RANS solver, so I set up a fieldAverage of the scalars to calculate the Mean and Prime2Mean values. If I am not mistaken, Prime2Mean is simply the square of the standard deviation. When the calculation was complete, I got a Prime2Mean value very close to 0 which I believe means that the average flow and the instantaneous flow are the same at all points in time, which I know is not true.
Can anyone shine some light on to what I may have done incorrectly? Is there a better way to do this that I am not aware of?
Thanks,
Bryce
LWhitson2 is offline   Reply With Quote
rans, reactingfoam, turbulence
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
