May 8, 2012, 17:49 |
FOAM FATAL IO ERROR for chtMultiRegionFoam
#1 | |
YuanLiu
Rep Power: 16 |
Hello Everyone,
I create a case based on this thread: http://www.cfd-online.com/Forums/ope...tml#post259005 0-folder: contains domain folders with their respective data fields without polyMesh folders. constant-folder: regionProperties file and domain folders. Each domain has properties files, AND polyMeshes folder. system: in main folder controlDict and individual domain folders. In domain subfolers: fv-files. The case worked when I am using the chtMultiRegionSimpleFoam. Then I modified it a little bit,and try to run it using chtMultiRegionFoam command. And I got this error message: Quote:
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
