May 7, 2012, 12:17 |
Recreation of phi file, icoFoam
Madeleine P. Vincent
Rep Power: 15 |
Hi all,
I have a question about the phi file created in the time directories during an icoFoam run. I understand it to be a flux field through cell surfaces. It is generated if not present at time 0. [But I'm unclear on what is fluxing here, with units of m^3 / s]. It will also be re-generated if it is deleted after the simulation has started, though I get different results in this case. For example, if I start a simulation and run it for, say, 0.5 seconds. At this point I either delete the phi file in directory 0.5 seconds, or I don't. Run both cases until 1.0 seconds. The analysis in which the phi file was deleted states that the phi file is being re-created: "Reading/calculating face flux field phi" and in deed in the next step 0.51 directory, it is present. But the results (velocity, pressure) are significantly different at time 1.0. So my questions are: 1) what does the phi file represent 2) why is it not recreated identically if it is not present after a restart 3) is there any way to have it recreated so that the analysis is identical Thanks for your help, Madeleine |
icofoam, phi, recreated file |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 14:14 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
