May 2, 2012, 00:50 |
rhoPimpleFoam floating point error
Daniel
Rep Power: 17 |
Hello all,
I am trying to run a NACA0012 airfoil in OF 2.0.1. My case works in pimpleFoam, and I am trying to make it work in rhoPimpleFoam. This is where I run into trouble. After some iterations, I get a floating point error: Code:
[3] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::calculate() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" [3] #4 Foam::hPsiThermo<Foam::pureMixture<Foam::sutherlandTransport<Foam::specieThermo<Foam::hConstThermo<Foam::perfectGas> > > > >::correct() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so" [3] #5 [3] in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" [3] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 [3] in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" [dan-XPS-8300:00764] *** Process received signal *** [dan-XPS-8300:00764] Signal: Floating point exception (8) [dan-XPS-8300:00764] Signal code: (-6) [dan-XPS-8300:00764] Failing at address: 0x3e8000002fc [dan-XPS-8300:00764] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36420) [0x7fbeeb902420] [dan-XPS-8300:00764] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fbeeb9023a5] [dan-XPS-8300:00764] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36420) [0x7fbeeb902420] [dan-XPS-8300:00764] [ 3] /opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so(_ZN4Foam10hPsiThermoINS_11pureMixtureINS_19sutherlandTransportINS_12specieThermoINS_12hConstThermoINS_10perfectGasEEEEEEEEEE9calculateEv+0x342) [0x7fbeef093c42] [dan-XPS-8300:00764] [ 4] /opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so(_ZN4Foam10hPsiThermoINS_11pureMixtureINS_19sutherlandTransportINS_12specieThermoINS_12hConstThermoINS_10perfectGasEEEEEEEEEE7correctEv+0x32) [0x7fbeef0990c2] [dan-XPS-8300:00764] [ 5] rhoPimpleFoam() [0x41e185] [dan-XPS-8300:00764] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fbeeb8ed30d] [dan-XPS-8300:00764] [ 7] rhoPimpleFoam() [0x419b69] [dan-XPS-8300:00764] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 764 on node dan-XPS-8300 exited on signal 8 (Floating point exception). Code:
unset FOAM_SIGFPE Code:
Courant Number mean: 0.0240962 max: 0.900198 deltaT = 1.6889e-05 Time = 0.133221 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.000366418, Final residual = 2.27145e-09, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.000487366, Final residual = 1.37609e-08, No Iterations 2 smoothSolver: Solving for h, Initial residual = 0.000464378, Final residual = 2.25201e-09, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00780075, Final residual = 1.05014e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00378365, global = 0.00357667, cumulative = 4.21379 rho max/min : 2.50066 0.494607 GAMG: Solving for p, Initial residual = 0.00388573, Final residual = 5.73108e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00378365, global = 0.00357667, cumulative = 4.21737 rho max/min : 2.50066 0.494607 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.000173541, Final residual = 3.69469e-11, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.000244685, Final residual = 6.60247e-11, No Iterations 5 smoothSolver: Solving for h, Initial residual = 0.000945961, Final residual = 8.78996e-11, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0278345, Final residual = 7.14718e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00378365, global = 0.00357667, cumulative = 4.22095 rho max/min : 2.50033 0.497303 GAMG: Solving for p, Initial residual = 0.0141121, Final residual = 4.07318e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00378365, global = 0.00357667, cumulative = 4.22452 rho max/min : 2.50033 0.497303 smoothSolver: Solving for omega, Initial residual = 1.71392e-07, Final residual = 3.26293e-11, No Iterations 3 smoothSolver: Solving for k, Initial residual = 4.32051e-06, Final residual = 7.16007e-11, No Iterations 4 PIMPLE: not converged within 2 iterations ExecutionTime = 1261.98 s ClockTime = 1270 s Courant Number mean: 0.0240905 max: 0.90035 deltaT = 1.68805e-05 Time = 0.133238 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.000366052, Final residual = 2.27079e-09, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.000487299, Final residual = 1.35382e-08, No Iterations 2 smoothSolver: Solving for h, Initial residual = 0.000767231, Final residual = 2.28888e-09, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0288855, Final residual = 1.03388e-08, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00479274, global = 0.00458523, cumulative = 4.22911 rho max/min : 2.50067 0.494011 GAMG: Solving for p, Initial residual = 0.0142369, Final residual = 5.55694e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00479274, global = 0.00458523, cumulative = 4.23369 rho max/min : 2.50067 0.494011 PIMPLE: iteration 2 smoothSolver: Solving for Ux, Initial residual = 0.000170074, Final residual = 3.71863e-11, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.000244105, Final residual = 6.48768e-11, No Iterations 5 smoothSolver: Solving for h, Initial residual = 0.00239322, Final residual = 8.97771e-11, No Iterations 4 GAMG: Solving for p, Initial residual = 0.145301, Final residual = 7.51346e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00479275, global = 0.00458523, cumulative = 4.23828 rho max/min : 2.50034 0.497625 GAMG: Solving for p, Initial residual = 0.0783762, Final residual = 4.55685e-09, No Iterations 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0.00479275, global = 0.00458523, cumulative = 4.24286 rho max/min : 2.50034 0.497625 smoothSolver: Solving for omega, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000 [0] [0] [0] --> FOAM FATAL IO ERROR: [0] wrong token type - expected Scalar, found on line 3 the word 'nan' [0] [0] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] wrong token type - expected Scalar, found on line 3 the word 'nan' [1] [1] file: /home/dan/OpenFOAM/dan-2.0.1/run/cases/comp_trans_finetune/transBackRho/processor1/system/data::solverPerformance::k at line 3. [1] [1] From function operator>>(Istream&, Scalar&)[2] [2] [2] --> FOAM FATAL IO ERROR: [2] wrong token type - expected Scalar, found on line 3 the word 'nan' [2] [2] file: /home/dan/OpenFOAM/dan-2.0.1/run/cases/comp_trans_finetune/transBackRho/processor2/system/data::solverPerformance::k at line 3. [2] [2] From function operator>>(Istream&, Scalar&) [2] in file lnInclude/Scalar.C at line 91. [2] FOAM parallel run exiting [2] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] wrong token type - expected Scalar, found on line 3 the word 'nan' [3] [3] file: /home/dan/OpenFOAM/dan-2.0.1/run/cases/comp_trans_finetune/transBackRho/processor3/system/data::solverPerformance::k at line 3. [3] [3] From function operator>>(Istream&, Scalar&) [3] in file lnInclude/Scalar.C at line 91. [3] FOAM parallel run exiting [3] file: /home/dan/OpenFOAM/dan-2.0.1/run/cases/comp_trans_finetune/transBackRho/processor0/system/data::solverPerformance::k at line 3. [0] [0] From function operator>>(Istream&, Scalar&) [0] in file lnInclude/Scalar.C at line 91. [0] FOAM parallel run exiting [0] [1] in file lnInclude/Scalar.C at line 91. [1] FOAM parallel run exiting [1] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 2 with PID 30679 on node dan-XPS-8300 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [dan-XPS-8300:30676] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [dan-XPS-8300:30676] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Thanks in advance, Dan |
May 2, 2012, 07:12 |
Olivier
Rep Power: 18 |
hello,
Try to set relTol at zero for p, and lower you maxCo in control dict (max 0.25) regards, olivier |
May 2, 2012, 21:28 |
Daniel
Rep Power: 17 |
Hello Olivier,
Thanks for the response. I will try that, though I am concerned about using maxCo 0.25 for practical reasons. Using an implicit code, and all of the time schemes are implicit in OF, I should be able to get away with using a much higher Co - my advisor suggested 20-50 is not unreasonable. Why is it that OF seems to require such low Co numbers to function? Thanks, Dan |
May 3, 2012, 04:09 |
Olivier
Rep Power: 18 |
hello,
Can you share your BC, (k & omega BC) ? Something may be wrong with that. regards, olivier |
May 3, 2012, 21:05 |
Daniel
Rep Power: 17 |
Hello Olivier,
Thanks for your interest. Please find attached my 0 directory. Regards, Dan |
December 12, 2013, 23:08 |
starter
Rep Power: 16 |
Daniel
I am having the same error using simpleFoam. Can you please advise how you resolved this nan issue. regards |
January 5, 2014, 21:57 |
Daniel
Rep Power: 17 |
Unfortunately, I never did resolve the issue. Moved to rhoCentralFoam instead. Regards, Daniel |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
