April 30, 2012, 15:09 |
pisoFoam solver error
anurag
Hi all,
i'm trying to simulate an axisymmetric jet in OpenFoam using the pisofoam solver......when i run the solver....after one or two time steps ,it gives an error............i'm providing u with my blockMeshDict file and the error............... /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters .001; vertices ( (0 0 0)//0 (-10 0 0)//1 (-10 4.9952 -.218166)//2 (0 4.9952 -.218166)//3 (-10 4.9952 .218166)//4 (0 4.9952 .218166)//5 (2000 4.9952 .218166)//6 (2000 4.9952 -.218166)//7 (2000 0 0)//8 (0 998.096 -43.633)//9 (0 998.096 43.633)//10 (2000 998.096 43.633)//11 (2000 998.096 -43.633)//12 ); blocks ( hex (3 7 6 5 0 8 8 0) (50 1 50) simpleGrading (1 1 1) hex (9 12 11 10 3 7 6 5) (50 1 50) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 3 5 0) ) patch outlet ( (8 7 6 8) (7 12 11 6) ) wall upperwall ( (3 9 10 5) ) wedge front ( (0 5 6 8) (5 10 11 6) ) wedge back ( (3 7 12 9) (0 8 7 3) ) empty bases ( (0 8 8 0) ) ); mergePatchPairs ( ); the error is......... Time = 0.05 Courant Number mean: 1.28732e+80 max: 1.07637e+83 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #8 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pisoFoam" #9 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pisoFoam" #10 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pisoFoam" #11 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #12 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pisoFoam" Floating point exception i would appreciate your help...................................... |
May 1, 2012, 10:08 |
Santiago Marquez Damian
Rep Power: 24 |
Checking... ... ... ... Not enough info for problem diagnose, please post you system/ and 0/ files ... Abort
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
May 2, 2012, 07:01 |
Hello Akkupant,
I have checked your case, I am not able to see inlet in your case. please check your blockMeshDict file, the defined patches are correct or not. I will get back to you in 3 to 4 hours. check the below fig, is it correct? if yes just tell me your inlet and outlet. with regards, Sivakumar |
May 2, 2012, 07:12 |
Hello Akkupant,
I have checked your case, I am not able to see inlet in your case. please check your blockMeshDict file, the defined patches are correct or not. check the attached fig, is it correct? if yes just tell me your inlet and outlet. with regards, Sivakumar Last edited by sivakumar; May 2, 2012 at 10:30. |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 06:56 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 21:11 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
