unsteady LES pisoFoam questions
Old   April 21, 2012, 09:03
Default unsteady LES pisoFoam questions
Garrison, Liang
garrison is on a distinguished road
Hi everyone! I am a graduate in CFD with little experience...
I use pisoFoam to do a DES(LES). It's certainly an unsteady three dimension case.
I try to use simpleFoam to get a initial state of the flow and then change the simulation to a LES one.
When running LES, I find the Initial residual of Ux and Uz is quite small and it didn't iterate at all, I don't think that's right, but the p still interate. does that mean I get a steady flow? Or is that because the grid I use is too coarse? My deltaT=1e-6, Uref=8m/s, and Re=2e5.
One more question.. how do people usually do to check if the grid is good enough for LES?
I paste some detail of my scheme blow, maybe someone can tell me whether the scheme I'm using is to dissipate for LES. and I also put what the monitor show...
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss filteredLinear;
div(phi,B) Gauss limitedLinear 1;
div(phi,R) Gauss limitedLinear 1;
div(phi,nuTilda) Gauss limitedLinear 1;
div(B) Gauss linear;
div(R) Gauss linear;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DBEff,B) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
Time = 0.030544
Courant Number mean: 0.000694429 max: 1.20379
DILUPBiCG: Solving for Ux, Initial residual = 2.18816e-07, Final residual = 2.18816e-07, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1.07832e-06, Final residual = 1.05828e-11, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 7.56565e-07, Final residual = 7.56565e-07, No Iterations 0
GAMGPCG: Solving for p, Initial residual = 0.000125884, Final residual = 5.7209e-06, No Iterations 3
time step continuity errors : sum local = 7.56596e-15, global = -2.91722e-16, cumulative = -5.83468e-13
GAMGPCG: Solving for p, Initial residual = 3.95052e-05, Final residual = 2.33747e-06, No Iterations 1
time step continuity errors : sum local = 3.09128e-15, global = -3.06279e-18, cumulative = -5.83471e-13
smoothSolver: Solving for nuTilda, Initial residual = 5.36636e-07, Final residual = 1.36181e-08, No Iterations 1
ExecutionTime = 15477.9 s ClockTime = 15525 s
Calculating averages
forceCoeffs output:
Cd = 0.0651411
Cl = 0.488558
Cm = -0.382946
Thanks in advance.
Best Regards
Garrison
garrison is offline   Reply With Quote
Old   April 22, 2012, 03:13
Alberto Passalacqua
I would recommend to start from a perturbed solution, rather than from a steady-state solution, or it will take an extremely long time for structures to develop (assuming they will).
The idea is that the filter size should be in the inertial subrange of the spectrum, so that you can make the assumption SGS viscosity. In other words, you have to resolve all the non-isotropic scales. If you check the literature (S. Pope book for example), there are formulae to obtain estimates.
The numerics looks fine.
Best,
Alberto Passalacqua
Old   April 22, 2012, 07:24
Garrison, Liang
Thank you Alberto!
"a perturbed solution", can you tell me which solver shall I use to get a initial state?
and if I start with a steady-state solution, you mean the LES/DES will take an extremely long time to develop the structures?
Best Regards
Old   April 23, 2012, 12:26
Alberto Passalacqua
Hi Garrison,
there are various approaches in the literature to generate a perturbed flow field that can be used as initial condition. Unfortunately these apply to relatively simple flows. If you have a complex geometry, the easy way is to initialize the velocity field with a random field based on your mean velocity and fluctuations (which change locally). Hopefully this will help the flow develop quickly.
A more sophisticated alternative is to use synthetic turbulence at inlet BC's, if you have time to implement it into your code.
About your second question: yes, generating a fully developed turbulent flow with LES can be very time consuming. That's why it is advisable to start from a flow already containing turbulent structures (you can use the flow field obtained from previous simulations).
Best,
Alberto Passalacqua
Old   April 23, 2012, 23:42
Garrison, Liang
Once again thank you Alberto.
So can I use the turbulentInlet as the inlet B.C., can it function as the synthetic turbulence B.C.?
In turbulentInlet B.C., One can give the velocity a fluctuation I think,
type turbulentInlet;
fluctuationScale (0.01 0.01 0);
referenceField uniform (8 0 0);
value uniform (8 0 0);
Best Regards
Old   April 23, 2012, 23:46
Alberto Passalacqua
Unfortunately turbulentInlet only adds noise to the mean value. It might help (in other words, try), but it is not a true synthetic turbulence generator, where the procedure aims at reproducing at least some of the features of the turbulent flow.
To my knowledge, there is no synthetic turbulent BC available in OpenFOAM, however some user on this forum implemented some of them. Maybe a search will give you more information.
Best,
Alberto Passalacqua
Old   April 23, 2012, 23:52
Garrison, Liang
Thank you Alberto, you really helped me lot.
I'll search more.
Old   July 24, 2012, 11:33
Default Albeto plz help me
vahid
vahid.najafi is an unknown quantity at this point
Hi,Alberto.
I'm working with openFoam 2.0.1,and have a problem with solver (interPhaseChangeFoam) in multiphase solvers.
my friends tell me, you can help me.
I have add (turbulence kinetic Energy or k ) in a part of this solver.
first:
added:
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/RASModel \
in option.
and then:
added
//.................................................. .....changed
// Construct incompressible turbulence model
autoPtr<incompressible::RASModel> turbulence
incompressible::RASModel::New(U, phi, twoPhaseProperties())
in creatField.
and then:
added
#include "RASModel.H"
and:
volScalarField turbKinEnergy = turbulence().k(); //turbKinEnergy = turbulence().k();
volScalarField turbDisEnergy = turbulence().epsilon();
in this and turbkinEnergy=k
in myinterPhaseChangeFoam.c
and wmake is ok!!!
but
I want in this solver in directory:
/run/myinterPhaseChangeFoam/phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.c
I added
in it and:
Foam::tmp<Foam::volScalarField>
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff
const volScalarField& p
) const
volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1)));
volScalarField rho
limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2()
return
//......I want to change it( <<k>> turbulence multiple in it):
(3*rho1()*rho2())*sqrt(2/(3*rho1()))*k()
*rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat()));
dont successful wmake, and seen(was not declared ):
I/opt/openfoam201/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SchnerrSauer.o
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C: In member function â€کFoam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff(const Foam::volScalarField&) const’:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: k() was not declared in this scope
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1
please help me alberto.
vahid.najafi is offline   Reply With Quote
Old   July 24, 2012, 23:45
Alberto Passalacqua
The interphaseChangeFoam solver has generic turbulent implementation by itself in OpenFOAM 2.1.x. Use the latest version.
P.S. Please do not send personal emails to ask technical questions you already posted on the forum.
Alberto Passalacqua
Old   July 25, 2012, 11:33
Default plz give me your interPhaseChangeFoam file
vahid
hi alberto.Thanks for your answer.
I dont have good internet,please give me interPhaseChangeFoam file from your openFoam 2.1.x to me.
Thanks a lot
Old   July 25, 2012, 12:26
Alberto Passalacqua
You need the whole OpenFOAM 2.1.x to be able to use the solver. Probably the best way for you to get it is to use the git repository.
Alberto Passalacqua
Old   July 28, 2012, 02:11
Default Plz help me!!
  #12
vahid
Hi Dear Alberto.
I used openFoam 2.1.x for solver interPhaseChangeFoam but my problem is not ok!!!
my prob is:
I added
in it and:
) const
volScalarField rho
return
Old   July 28, 2012, 02:15
Alberto Passalacqua
Originally Posted by vahid.najafi View Post
Hi Dear Alberto.
my prob is:
You do not need to add the equation for the turbulent kinetic energy in the solver provided with OpenFOAM 2.1.x, since it is already there. Simply turn the turbulence model on in the turbulenceProperties dictionary, and configure the case as needed, adding k and epsilon fields to the 0 folder.
Note that #include "turbulenceModel.H" is already in the code :-)
Best,
Alberto Passalacqua
Old   August 17, 2012, 21:12
maalan is on a distinguished road
Hi all!! I see you have a solid background in OpenFOAM and turbulent cases, so I hope you coulp hand me on. The point is I'm stucked with a flow past a bluff body (ahmed model) but I don't get an unsteady wake using pisoFoam. I have a structured mesh with a finer region in the near wake zone, CFL<0.5, keRNG model, etc... I'm running pisoFoam from a simpleFoam solution, is this the problem? What's the way to introduce a pertubartion to break the symmetry or something like that? I attach my fvSchemes...
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default backward;//CrankNicholson 0.5;//steadyState;
gradSchemes
// grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;//vanLeerV;//linearUpwindV Gauss linear;
div(phi,k) Gauss limitedLinear 1;//upwind;
div(phi,epsilon) Gauss limitedLinear 1;//upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DnuTildaEff) Gauss linear corrected;
laplacian(1,p) Gauss linear corrected;
// default Gauss linear corrected;
// default Gauss linear limited 0.5;
// default Gauss linear limited 0.333;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Thanks!!
Best,
maalan is offline   Reply With Quote
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 11:56
Some questions about LES in OpenFoam A.Devesa OpenFOAM Running, Solving & CFD 3 July 26, 2010 09:35
batch file script to run unsteady flow (les) andi FLUENT 0 April 20, 2004 04:50
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
LES unsteady : Turbulent Mixing Layer Flav FLUENT 5 December 13, 1999 04:11
