alphaEqn in multiphaseInterFOAM 2.1
Old   March 8, 2012, 06:23
Default alphaEqn in multiphaseInterFOAM 2.1
Sina Saremi
sina.s is on a distinguished road
Hi all!
multiphaseInterFOAM didn't give physical results in previous versions, until it has been modified in version 2.1, and the results are now apparently acceptable. So I have decided to use this solver for my 3 phase case.
I need to make some minor modifications in the phase transport equations (alpha equations).
In previous versions, the alphaEqn could clearly be seen in the multiphaseMixture.C file (line 528), but the same file in version 2.1 has gone under changes and now I can not see any alphaEqn anywhere in the solver!
I would be pleased if someone could tell me where and how the transport equations are solved in this solver?
Sina
sina.s is offline   Reply With Quote
Old   March 8, 2012, 12:15
akidess's Avatar
Anton Kidess
The solution call is now in a separate class Foam::multiphaseMixture::solve(). See multiphaseInterFoam/multiphaseMixture/multiphaseMixture.C
- Anton
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   March 9, 2012, 05:30
Sina Saremi
Thanks Anton! yes it seems that the alpha equations are taken care by MULES (in a similar way as in InterFoam).... and that probably makes it more difficult to make some personal changes in them
Sina
alphaeqn, multiphaseinterfoam, version 2.1
No reactions in reactingFoam 2.1 OMN OpenFOAM Running, Solving & CFD 16 April 7, 2015 13:14
[Other] From Pointwise to OpenFoam 2.1 cyclicAMI... lordvon OpenFOAM Meshing & Mesh Conversion 9 February 9, 2015 16:08
VOF fraction in multiphaseInterFoam mahaputra OpenFOAM Running, Solving & CFD 1 August 27, 2009 09:15
Possible bug in multiphaseInterFoam msrinath80 OpenFOAM Bugs 16 March 25, 2008 21:09
FIDAP on glibc 2.1 Ingo Meisel FLUENT 2 February 1, 2002 06:15
