Meaning of "fvc::div(phi)"
Like Tree60Likes
Old   March 25, 2015, 09:22
Przemek
gaza is on a distinguished road
Hi all
I have only the question why divU = fvc::div(phi)
When we see in the prof. Jasak's PhD in Eqn. 3.15 we have that: divU = sum(S.Uf)/Vp
where Vp is a volume of the cell.
So why in the code we don't have to do division by the cell volume?
best regards
pblasiak
gaza is offline   Reply With Quote
Old   May 26, 2018, 04:23
kc95 is on a distinguished road
Originally Posted by sharonyue View Post
U make it very very clear, Thanks very much. So I just make it a example.:
1. volVectorField U;
fvc::div(U);
2. volVectorField U;
phi = U & mesh.Sf();
fvc::div(phi);
So these two functions are the same rite? fvc::div(u)=fvc::div(phi).
Looks like div() has been overloaded.
I make a testify:
fvc::div(HbyA)dimensions      [0 0 -1 0 0 0 0];
internalField   nonuniform List<scalar> 9(0.000569046 -8.589e-06 -0.000648869 -0.00128281 0.000183935 0.00124553 0.00416702 3.71583e-06 -0.00422898);
fvc::div(phiHbyA):dimensions      [0 0 -1 0 0 0 0];
Its total the same. Good job.
How did you find out these numerical values? i am very new to OF. so my question might appear as silly. But, please do reply. Thanks in advance!!
kc95 is offline   Reply With Quote
Old   May 26, 2018, 04:28
fvc::div(U);
fvc::div(phi);
I make a testify:
How did you get this numerical values? I am very new to OpenFOAM, so the question might appear as very silly. Please do reply. Thanks in Advance!!
Old   May 26, 2018, 10:23
Felipe Alves Portela
fportela is on a distinguished road
What exactly do you want to know?
fportela is offline   Reply With Quote
Old   May 26, 2018, 10:30
How did you get these values of fvc::div(phiHbyA) as wellas fvc:HbyA)?
I mean, how can we calculate and display those values?
Old   July 1, 2018, 13:44
Reviewer #2
randolph is on a distinguished road
fvc::div(U);
fvc::div(phi);
I make a testify:
1. From the continuity equation, the divergence-free condition is strictly applied to the face flux in the FVM. So it makes sense that cell value is not strictly divergence free.
2. However, I am still confused that why fvc::div(U) = fvc::div(phi) ? Isn't the phi = U*A?
randolph is offline   Reply With Quote
Old   October 13, 2020, 01:39
Default Display value of fvc::div(HbyA)
  #27
Duc Anh
anhkenyt is on a distinguished road
fvc::div(U);
fvc::div(phi);
I make a testify:
I tried it in peqn.H in pisoFoam like that:
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
    "phiHbyA",
    fvc::flux(HbyA)
  + MRF.zeroFilter(fvc::interpolate(rAU)*fvc::ddtCorr(U, phi))
Info<<"fvc::div(phiHbyA): "<<fvc::div(phiHbyA)<<endl;
Info<<"fvc::div(HbyA): "<<fvc::div(HbyA)<<endl;
But I faced to error
FOAM FATAL IO ERROR:
keyword div(HbyA) is undefined in dictionary "/home/anh/OpenFOAM/anh-6/applications/solvers/src/cyclicSimpleFoam/system/fvSchemes.divSchemes"
And this is my divSchemes
divSchemes
    default         none;
	div(HybA)  Gauss upwind; //vda add
//	div(U)  	 Gauss upwind; //vda add
	div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,k)      bounded Gauss limitedLinear 1;
    div(phi,epsilon) bounded Gauss limitedLinear 1;
    div(phi,omega)  bounded Gauss limitedLinear 1;
    div(phi,v2)     bounded Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
    div(nonlinearStress) Gauss linear;
Anyone could help me display this value ?
anhkenyt is offline   Reply With Quote
Old   October 13, 2020, 09:35
Przemek
add this
div(HbyA)      Gauss upwind;
ps
you have the typo "HybA" instead of "HbyA"
best regards
pblasiak
Old   October 13, 2020, 10:13
Duc Anh
Originally Posted by gaza View Post
add this
ps
Thanks for the quick answer, sorry about my stupid mistake. However when I fixed it,
divSchemes
    default         none;
	div(HbyA)  Gauss upwind; //vda add
I have another error:
fvc::div(HbyA):
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/anh/OpenFOAM/anh-6/applications/solvers/src/vda_meanVelocityForce/testcode/cyclicSimpleFoam/system/fvSchemes.divSchemes.div(HbyA) at line 31.
Could you give me some suggestions?
Old   October 13, 2020, 12:10
Hojatollah Gholami
Hgholami is on a distinguished road
Hi
I want to write below equation to foam-extend 4.0
I thought to use
fvScalarMatrix pEqn
fvm::grad(p) == fvc::div(U)/runTime().deltaT().value()
pEqn.solve();
but I know it's wrong. Do you have any tip for this?
Thanks.
Hgholami is offline   Reply With Quote
Old   October 13, 2020, 13:03
Duc Anh
Originally Posted by Hgholami View Post
Hi
I thought to use but I know it's wrong. Do you have any tip for this?
Thanks.
Hi Hgholami,
In your equation, does not grad p, It should be lapacian(p). You can try:
fvScalarMatrix pEqn
fvm::laplacian(p) == fvc::div(U)*rhoF/dT
However, I don't know to extract the meaning of index "p" and "n+1" in your eqn.
Old   October 13, 2020, 13:40
Przemek
divSchemes
    default         none;
fvc::div(HbyA):
try Guass linear maybe
you wrote something in fvSchemes
anhkenyt likes this.
best regards
pblasiak
Old   October 13, 2020, 23:22
Hojatollah Gholami
Hi Hgholami,
Hi anhkenyt
I want to use fractional-step projection method.
the index "p" and n+1 is not matter. they are predicted velocity and next time step, respectively.
my mistake may be comparison delta_t with delta_p in Eq. 10.
Old   May 3, 2022, 15:43
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
I am trying to write a new Particle Dispersion Model in OpenFOAM. The model requires the divergence of the Reynolds stress tensor. I am able to read the Reynolds stress tensor into the model and am able to perform the fvc::div operation.
My doubt is if this approach is correct. I tried fvc::div(U) in the same way and it gave really high values (O(1)) which are not correct because the simulation has converged and the fvc::div(U) should be a small value (O(1e-3)). So now I have doubts if fvc::div(R) is giving the right values.
I have the phi variable too which I think is U*surfaceArea. I computed div(phi, U) and div(phi), and both gave small values in O(1e-3).
Should I be using phi to compute the divergence of R? I am getting an error if I use fvc::div(phi,R). What is the difference between using div(R) and div(phi,R)?
saiguruprasad is offline   Reply With Quote
Old   July 29, 2022, 15:05
Not applicable
kagen816 is on a distinguished road
Hi Sai,
Have you found any clue, I found a similar problem. fvc::div(U) has a much greater value than fvc::div(phi) but they have the same dimension!
Thanks
kagen816 is offline   Reply With Quote
Old   July 30, 2022, 09:40
Hi Kagen816.
It seems that div(phi) is correct if you want to verify the continuity equation. phi corresponds to the flux, while U is the cell centre value of velocity.
Divergence needs to be calculated at the faces.
But I am not sure how this applies to other variables. I am still looking at div(R), where R is the Reynolds Stress.
kagen816 likes this.
Cyclic Boundary creation, what's the meaning of "separationVector" panda60 OpenFOAM 5 April 12, 2023 18:51
What's meaning of UDF FUNCTION zhaoxinyu Fluent UDF and Scheme Programming 0 March 31, 2010 09:04
meaning of residual p-mass ? Dele CFX 0 March 4, 2008 04:23
want to know meaning Sangamesh Siemens 0 May 15, 2007 06:15
What's the meaning of "combustion scalar"and.... cfdbeginner CFX 0 November 27, 2003 10:02
