buoyanSimpleFoam
Old   February 28, 2012, 05:01
Default buoyanSimpleFoam
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to create my own solver, following this tutorial.
What I wanna do is to modify the buoynatSimpleFoam solver in order to make it possible to fix the value of the enthalpy (hence, of the temperature) in some cells.
The point is that when I create my new folder (e.g. buoyantSimpleFoamMod) and try to compile the code (after having edited also the files in it) I get this error message:
wxpmi213:/opt/openfoam201/applications/solvers/heatTransfer/buoyantSimpleFoamMod # wmake
/opt/openfoam201/wmake/wmake: line 222: make: command not found
/opt/openfoam201/wmake/wmake: line 223: make: command not found
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /opt/openfoam201/applications/solvers/heatTransfer/buoyantSimpleFoamMod
Could you help, please?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   February 28, 2012, 15:50
Anja Miehe
AnjaMiehe is on a distinguished road
Hello Samuele,
you have to do all the comments of the tutorial in your home folder. Normally, you are not allowed to compile with wmake in /opt/... and it is not advisable. Start anew in /home/Samuele, there it should work.
Have a nice evening, Anja
AnjaMiehe is offline   Reply With Quote
Old   February 28, 2012, 17:49
Retired Super Moderator
Bruno Santos
Greetings Samuele and Anja,
Anja is right: you should not use the "/opt" folder for developing experimental solvers
The tutorial clearly talks about using "$WM_PROJECT_USER_DIR" as your work area. If you do not know what this variable indicates, run:
echo $WM_PROJECT_USER_DIR
This fixes the second problem. The first problem is highlighted in bold:
Originally Posted by samiam1000 View Post
This means that make is not installed. For having a working development environment, check the requirements from here: System Requirements
You only need to install the packages mentioned on the System Requirements section, for the Linux version that you are using.
Best regards,
Bruno
Old   February 29, 2012, 03:39
Samuele Z
Hi All,
and thanks for answering.
I have solved the second problem, but the first one still stands, since I can not install software on my laptop. I have to ask to the IT office to do that and that's what I am gonna do asap.
Thanks again.
And I hope to solve this question, soon.
Later I'll probably have questions about fluid dynamics and not about computer science .
Thanks again,
Samuele
