How to compile a new solver in OpenFOAM-2.1.0?
Like Tree12Likes
Old   July 27, 2016, 04:30
Default compile a solver
  #21
A. Min
alimea is on a distinguished road
Hi guys
I'm using O.F. is 2.3.1 and have done changes according to http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
But I've gotten this error:
make: *** [Make/linux64GccDPOpt/icoHeatFoam.o] Error 1
Help me, if you know the solution.
Thanks
alimea is offline   Reply With Quote
Old   July 27, 2016, 04:43
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Originally Posted by alimea View Post
Hi guys
Thanks
Hi Ali,
please post the error description completely (what you see in the terminal).
Regards,
Mostafa
adambarfi is offline   Reply With Quote
Old   July 27, 2016, 04:48
A. Min
Thanks Mostafa.
These are all of the messages which are printed in terminal:
SOURCE=icoHeatFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/sampling/lnInclude -IlnInclude -I. -I/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoHeatFoam.o
In file included from icoHeatFoam.C:42:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:73:1: error: expected ‘)’ before ‘D0’
D0
In file included from icoHeatFoam.C:53:0:
/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
const int nOuterCorr =
/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
const bool momentumPredictor =
/home/drnili/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable]
const bool transonic =
Old   July 27, 2016, 04:53
adambarfi's Avatar
Mostafa Mahmoudi
Thanks Mostafa.
D0
look at the bold-red part in above.
you forgot to close the parentheses before the D0.
Old   July 27, 2016, 05:10
A. Min
volScalarField D
IOobject
"D",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
D0
I think I've forgotten a "," after mesh. isn't it?
But how can I be confident that my solver works correctly?
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam jovani OpenFOAM Running, Solving & CFD 475 January 13, 2023 09:21
Acoustic Solver with openfoam acoustica OpenFOAM Programming & Development 110 February 24, 2021 19:50
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
AMG solver in Openfoam gonski Main CFD Forum 0 November 25, 2007 06:20
