how to change a volScalarField in bc?
Like Tree14Likes
Old   February 2, 2012, 07:10
Francois
Fransje will become famous soon enough
Originally Posted by tomislav_maric View Post
From
OpenFOAM-1.6-ext/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity
comes:
void parabolicVelocityFvPatchVectorField::updateCoeffs()
    if (updated())
        return;
    // Get range and orientation
    boundBox bb(patch().patch().localPoints(), true);
    vector ctr = 0.5*(bb.max() + bb.min());
    const vectorField& c = patch().Cf();
    // Calculate local 1-D coordinate for the parabolic profile
    scalarField coord = 2*((c - ctr) & y_)/((bb.max() - bb.min()) & y_);
    vectorField::operator=(n_*maxValue_*(1.0 - sqr(coord)));
This is called upcasting in C++: stripping the inherited object to the base class. All bcs are hidden *fields. No need for *_cast magic.
Just so you don't miss it , the key line is
vectorField::operator=  blah blah
, this converts "this" (the class, in this case parabolicBlah...) to a vectorField.
T.
Dear Tomislav,
Thank you for your contribution, but this is missing the point slightly.
The const_cast< > here is used to be able to change an object / variable in the database, which is of type const, so theoretically not modifiable.
Kind regards,
Francois.
Fransje is offline   Reply With Quote
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 07:37
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 10:40
Is there a way to change the name a volScalarField liu OpenFOAM Running, Solving & CFD 2 October 18, 2007 18:49
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 03:33
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
