error compiling modified applications
Old   February 22, 2016, 13:07
Peter
potentialFoam is on a distinguished road
Still need help concerning that issue...
Further points I checked:
- in foam-folder:
grep -nr "fv::gaussConvectionScheme"
(other applications only use a laminar or upwind type, but nothing like QUICK or other higher order schemes)
- building the fvOptions-class in the directory $WM_PROJECT_USER_DIR (same error occurring)
Can someone help me with the error described in the last post?
potentialFoam is offline   Reply With Quote
Old   March 1, 2016, 05:53
Default Solved
  #22
Peter
Finally, one solution is to refer to the system/fvSchemes file with
volVectorField QUICKConvection ( fvc::div(phi, U, "div(phi,U)") );
if
div(phi,U) Gauss QUICK;
is specified in fvSchemes.
A further possibility would be to define a new name for the convective part
"div(phi,U)" -> "newName"
and define it inside fvSchemes.
error compile declare
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
modified CrossPowerLaw wmake error andboje OpenFOAM Programming & Development 13 October 12, 2010 14:07
flux seems not conserved in my modified scalarTransportFoam danielr OpenFOAM Running, Solving & CFD 3 October 5, 2009 17:05
Lunar applications anders_feder OpenFOAM Running, Solving & CFD 1 February 21, 2009 18:26
Modified Equation for CFX algorithm Craig Johansen CFX 0 August 28, 2004 00:02
