adding thermophysical model to conjugateHeatFoam
Old   December 1, 2011, 13:12
Default adding thermophysical model to conjugateHeatFoam
Helmut Roth
helmut is on a distinguished road
I want to add a thermophysical model to the fluid side of conjugateHeatFoam. It’s not going well!
To get started, I used rhoPisoFoam as a model to rewrite solveFluid.H, but solving for T+T, not h. After it all compiled, I got the runtime error message:
--> FOAM FATAL ERROR:
given field does not correspond to patch. Patch size: 10 field size: 0
From function PatchToPatchInterpolation::faceInterpolate(const Field<Type> ff)
in file /usr/local/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/PatchToPatchInterpolate.C at line 133.
FOAM aborting
gdb showed that the error was spawned by the coupled solver solving for T+T.
I backed up and took out all references to the turbulence and thermo models. Fields defined by the thermo model became defined in the 0/ directory (or got left out altogether). The code then ran.
Reinstating the code to create the thermo and turbulence models (without using them later in the solver) brought back the error. Both T eqns referenced rho and Cp in the ddt terms. Coupling those didn’t help. I made the application steady, basing solveFluid.H on rhoSimpleFoam. Then only k and T were common to both temperature equations:
coupledFvScalarMatrix TEqns(2);
// Add fluid equation
TEqns.set
0,
new fvScalarMatrix
fvm::div((fvc::interpolate(Cp)*phi), T)
- fvm::laplacian(k, T)
// Add solid equation
TEqns.set
1,
new fvScalarMatrix
-fvm::laplacian(kSolid, Tsolid)
TEqns.solve();
The problem remains: If I don’t create the thermo and turbulence models, the code runs, but when I create them I get the problem in the coupled T+T solution.
Any help will be greatly appreciated! Thanks.
helmut is offline   Reply With Quote
Old   December 8, 2011, 11:22
Helmut Roth
The above problem was solved by creating the thermo model after creating all of the fields. Simple, really.
conjugateheatfoam, thermophysical model
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
