declaration of an empty fvScalarMatrix
Old   November 11, 2011, 11:32
Default declaration of an empty fvScalarMatrix
Illya Shevchuk
linch is on a distinguished road
Hi fellows,
I want to underrelax some equation, so I have to declare fvScalarMatrix someEqn outside of my loop to prevent it from being deleted after each loop cycle right? But I can't use rubbish for initialization, because then it will be used for under-relaxation. So I need some kind of "empty" matrix, which will not be used for the relaxation. Is it possible? If not, can I prevent the under-relaxation in the first iteration?
best regards,
Ilya
linch is offline   Reply With Quote
Old   November 14, 2011, 07:28
Steven van Haren
stevenvanharen is on a distinguished road
Under-relaxation is already implemented in OpenFOAM.
See for instance pisoFOAM.
The amount of under-relaxtion can be controlled in fvSolution. Look for relaxtionFactors specified in fvSolution of some of the tutorials.
stevenvanharen is offline   Reply With Quote
Old   November 17, 2011, 08:09
Illya Shevchuk
Well, I know that the under-relaxation is already there, but my problem is that i have two loops, say i and j (j is the inner one) and I want to relax a matrix A in each j-iteration with the same value from the last i-iteration. Simplified:
for (i=0; i<n; i++)
  for (j=0; j>m;j++)
    A_new=...;
    A_new=fRel*A_new + (1-fRel)*A_old;  // relaxation
  A_old=A_new;
in other words, I want to update A_old in each outer but not in inner iteration. And relaxation implemented in OF takes the last available value of A_new, no matter where does it come from, right?
So either I could implement the relaxation by hand, or I could overwrite the previous value of A_new (how?) with A_old stored separately.
Which variant would you suggest me? Or do somebody have another ideas?
regards,
ilya
Old   November 22, 2011, 10:11
Illya Shevchuk
another question,
for a transient simulation, is F.oldTime() the same as F.prevIter(), where F is some vol...Field?
Are both of these fields stored? If so, can F.prevIter() be overwritten simply by using F.storePrevIter();? Where both of them are being stored per default: at runTime.write(), runTime++ or somewhere else?
In GeometricField.C I saw additional outputs while using storePrevIter() and storeOldTime() inside of if(debug){}. How the debug mode can be switched on?
best regards,
ilya
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 23:01
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
