Implementing a new InjectionModel / RunTimeSelection Problems |
Samuel Vogel
Rep Power: 17 ![]() |
I would like to create a new injection model. This should be based on the: OpenFOAM-2.0.x/src/lagrangian/intermediate/submodels/ReactingMultiphase/InjectionModel/ReactingMultiphaseLookupTableInjection model. So I copied the source files of the folder above to my local workspace, renamed the files and classes (no code changes so far - just duplicating the code), updated the make/files accordingly and compiled a user library (libmySpray). The compilation worked fine. Then I linekd the user library to a custom solver (did the same procedure, copied a solver that was working with the original injection model above, renamed it without code changes, updated make/files and compiled it --> worked well). But when I am starting the solver, and putting the renamed, new InjectionModel into the corresponding dictFile, the new injectionModel is not recognized. It doesn't appear in the list that is showed when using a un-known injeciton model. What have I missed? Do I have to register the new InjectionModel in a source somewhere else, outside the copied source files from the directory given above? Could someone please explain how I can add this new submodel to the runtimeSelectableList? So far no compilaiton errors! Thanks, Sammy |
Samuel Vogel
Finally found the solution: I have to register the new injectionModel in the corresponding make* file in the folder:
OpenFOAM-2.0.x src/lagrangian/intermediate/parcels/include Then it is working! |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Problems implementing a boundary condition | ogloth | OpenFOAM Running, Solving & CFD | 3 | July 17, 2007 15:36 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
Inverse problems | Aleksey Alekseev | Main CFD Forum | 0 | May 12, 1999 15:38 |
