value of previous time step
Like Tree17Likes
Old   November 8, 2013, 10:47
akidess's Avatar
Anton Kidess
oldTime and prevIter both are useful, nothing is deprecated. As stated by David, you can use oldTime to go back multiple time steps (not just one as prevIter), and it manages the storing automatically. That of course only works if you actually need values from a previous timestep, not from subcycle iterations. The latter case is where you would typically use prevIter/storePrevIter, but of course you can also use it to store data from a previous time step.
- Anton
dkxls likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 10, 2014, 18:16
ooo
ooo is on a distinguished road
Does U.oldTime() gives us the value of previous time step, or last value of the field?
assume that we have this situation :
while (runTime.loop())
U = somevalue1 ;
U = somevalue2 ;
x = U.oldTime();
So x is somevalue1 or is the value of U at the previous time step ?
ooo is offline   Reply With Quote
Old   February 10, 2014, 21:10
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
U.oldTime() will give the values of U at previous time step.
ahmmedshakil is offline   Reply With Quote
Old   March 7, 2015, 16:35
openfoammaofnepo is on a distinguished road
Dear Marupio,
Your reply below is very helpful, but I have still the problems about
when "erased and reconstructed at every timestep" happens? At the beginning of each time step or at the end of the time step?
Thank you very much. OFFO
Originally Posted by marupio View Post
Yes, oldTime works much simpler than you think. It is all totally automatic in the background. You never need to call storeOldTime()... and the xn.oldTime() immediately gives you the value from the previous timestep. runTime is clever enough to count how many .oldTime()'s you use, and automatically stores that many in its database.
I think you are probably using a local object. I was always confused as to why xn wouldn't *already* have the previous timestep's value at the start of the next timestep. If you are using a local object, it is erased and reconstructed at every timestep. In this case, oldTime() won't work, and neither would a simpler vectorField copy we talked about either. Where are you constructing your xn object? Will the program encounter the constructor once and only once throughout multiple timestep iterations? If not, move the constructor above your while(runTime.loop())... possibly even into createFields.H. If this is the problem, that's probably why it didn't work when you were using a standard vectorField. I'd recommend returning to the vectorField framework if possible.
openfoammaofnepo is offline   Reply With Quote
Old   October 7, 2023, 22:51
Default hello
  #25
Grp
GrpOne123 is on a distinguished road
I want to get the mesh.Cf() of a patch in oldTime , how can i do that?
I try mseh.Cf().oldTime().boundaryField()[patch], it is no works.
GrpOne123 is offline   Reply With Quote
field, store, time step
Reading forces from previous time step within solver SD@TUB OpenFOAM Programming & Development 5 April 24, 2023 12:51
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
UDF: Previous time step macros NOT working jpapg FLUENT 0 April 30, 2011 22:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
