Starting field averaging using libFunctionObject after certain time |
May 7, 2013, 12:51 |
solution to non updating trackDict
#21 |
Eelco van Vliet
Rep Power: 19 |
The answer can be found in the function object source code: the fileModificationSkew si not allowed to be too large. Just create a directory
$HOME/.OpenFOAM/2.2.x or what ever you version is, copy $WM_PROJECT_DIR/etc/controlDict to this directory and modify the line fileModificationSkew 30 to something smaller. Then an update of a dictionary being tracked will result in a reread of it. Regards Eelco |
May 15, 2013, 17:06 |
reread the subdictionaries from an regIOobject
#22 |
Eelco van Vliet
Rep Power: 19 |
One more question on this topic
When a dictionary is re-read after an file-update, only the content at the 'top-level is read, not the sub-dictionaries. This can be seen in the file $FOAM_SRC/OpenFOAM/db/regIOobject/regIOobjectRead.C, line 285-292. It says: reread object name(), which is the name of the dictionary. however, sometimes you want to read the subdictionaries as well. For instance in kinematicCloudProperties, you want to update the mass flow rate of the injectors by modifying the file during the run. Is there an easy way to force OF to re-read the subdictionaries during a run ? Well, not so important, but it would be handy Thanks for the hints! Regards Eelco |
November 19, 2014, 09:53 |
#23 |
Hello Everyone
I am beginner in OpenFoam, may be my question looks very busy, I am sorry for that. I am using fieldAverage to get time-averaged of velocity. I get the time-averaged file in respective time step folder but I don't know how can I view this average field using paraview. When I load my case to paraview, it shows only entities which are present in "0" folder. It does not show averaged field i.e. UMean Regards Waqas |
October 19, 2015, 03:25 |
#24 |
Manjura Maula Md. Nayamatullah
Rep Power: 13 |
Hello Steven,
I am using 2.2.x version of OpenFoam. The averaging utility you attached give me a compilation error. Do you have an updated version of this utility? I greatly appreciate your support. MMMN |
December 7, 2015, 23:06 |
compile field meet error
#25 | |
Fengjiao Bian
Rep Power: 13 |
Hi, Steven !I also want to start field averaging at a certain time when the field is fully developed.I down load the field.zip and unzip it.Then I put the directory at the path home/OpenFoam and run 'wmake libso' to compile it. But it come to error like this:
[hpc@hpcserver:~/OpenFOAM/field$ wmake libso SOURCE=fieldAverage/fieldAverage/fieldAverage.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/finiteVolume/lnInclude -I/opt/openfoam222/src/meshTools/lnInclude -I/opt/openfoam222/src/lagrangian/basic/lnInclude -I/opt/openfoam222/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fieldAverage.o In file included from /opt/openfoam222/src/OpenFOAM/lnInclude/className.H:34:0, from /opt/openfoam222/src/OpenFOAM/lnInclude/typeInfo.H:57, from /opt/openfoam222/src/OpenFOAM/lnInclude/token.H:46, from /opt/openfoam222/src/OpenFOAM/lnInclude/Istream.H:47, from /opt/openfoam222/src/OpenFOAM/lnInclude/ISstream.H:39, from /opt/openfoam222/src/OpenFOAM/lnInclude/IOstreams.H:38, from /opt/openfoam222/src/OpenFOAM/lnInclude/VectorSpace.C:27, from /opt/openfoam222/src/OpenFOAM/lnInclude/VectorSpace.H:171, from /opt/openfoam222/src/OpenFOAM/lnInclude/Vector.H:44, from /opt/openfoam222/src/OpenFOAM/lnInclude/vector.H:39, from /opt/openfoam222/src/OpenFOAM/lnInclude/fieldTypes.H:35, from /opt/openfoam222/src/finiteVolume/lnInclude/volFieldsFwd.H:37, from fieldAverage/fieldAverage/fieldAverage.H:88, from fieldAverage/fieldAverage/fieldAverage.C:26: /opt/openfoam222/src/OpenFOAM/lnInclude/debugName.H:45:11: error: ?.ddFoam?.has not been declared class add##Tag##ToDebug \ ^ /opt/openfoam222/src/OpenFOAM/lnInclude/debugName.H:125:5: note: in expansion of macro ?.egisterDebugSwitchWithName? registerDebugSwitchWithName(Type, Type, Type::typeName_()) ^ /opt/openfoam222/src/OpenFOAM/lnInclude/className.H:145:5: note: in expansion of macro ?.efineDebugSwitch? defineDebugSwitch(Type, DebugSwitch) ^ fieldAverage/fieldAverage/fieldAverage.C:34:1: note: in expansion of macro ?.efineTypeNameAndDebug? defineTypeNameAndDebug(Foam::fieldAverage, 0); ^ /opt/openfoam222/src/OpenFOAM/lnInclude/debugName.H:46:5: error: expected unqualified-id before ?.?.token : \ ^ /opt/openfoam222/src/OpenFOAM/lnInclude/debugName.H:125:5: note: in expansion of macro ?.egisterDebugSwitchWithName? registerDebugSwitchWithName(Type, Type, Type::typeName_()) ^ /opt/openfoam222/src/OpenFOAM/lnInclude/className.H:145:5: note: in expansion of macro ?.efineDebugSwitch? defineDebugSwitch(Type, DebugSwitch) ^ fieldAverage/fieldAverage/fieldAverage.C:34:1: note: in expansion of macro ?.efineTypeNameAndDebug? defineTypeNameAndDebug(Foam::fieldAverage, 0); ^ make: *** [Make/linux64GccDPOpt/fieldAverage.o] Error 1] could you tell me how to fix the errors ? Quote:
December 7, 2015, 23:28 |
#26 |
Fengjiao Bian
Rep Power: 13 |
Hello, do you solver the problem caused by the different version? My OPENFOAM is the 2.2.2version.
libutilityfunctionobjects, swak4foam, timeactivatedfileupdate, trackdictionary |
Physical Reason for stability of Implicit Schemes? | radhakrishnan | Main CFD Forum | 26 | October 3, 2023 23:05 |
TwoPhaseEulerFoam and Boundary conditions | raagh77 | OpenFOAM Running, Solving & CFD | 99 | February 6, 2018 19:31 |
Field averaging in a certain time interval | misakagan | OpenFOAM Running, Solving & CFD | 1 | December 11, 2009 06:39 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
