boundary values
Old   August 5, 2011, 06:10
Default boundary values
OFU
Jennifer
OFU is on a distinguished road
can anybody tell me where the boundary values in OpenFOAM are set? Are the specified in the middle of the boundary cells, in the middle of the surfaces or in the boundary points of the boundary cells or ....? And how can I set there the values for the pressure and the velocity?
Thanks,
Jennifer
OFU is offline   Reply With Quote
Old   August 5, 2011, 07:56
Mohammad
m2montazari is on a distinguished road
hi Jennifer,
I dont have enough info about that but I know that values are usually set at boundary faces not cells. however I dont know values are set in boundary nodes or at the middle of boundary faces? I read in a paper that openfoam is cell-based solver. if this is true, values should be set in boundary face centres.
cheers,
m2montazari is offline   Reply With Quote
Old   August 8, 2011, 15:37
Alex
bigbang is on a distinguished road
I am new to openFOAM, but I just wrote a program with some borrowed code from the forum to set up non uniform boundary values.
It is my understanding that the value is stored at the center of each cell face.
Hope this helps.
bigbang is offline   Reply With Quote
Old   August 9, 2011, 04:43
OFU
Jennifer
thanks for your answers, bigbang and m2montazari.
Bigband, is there a possibilty to get the code you wrote from you?
Jennifer
Old   August 9, 2011, 07:27
Alex
The thread where I got the code and then troubleshooted it for openfoam 2.0.0 is here:
http://www.cfd-online.com/Forums/ope...tml#post319363
Good luck
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
error when calculating values at boundary using refCast prabhu OpenFOAM 7 March 12, 2018 09:31
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
Creating Face in CFD Post and export Values as Boundary Conditions flow87 CFX 2 June 4, 2011 05:06
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 14:47
