How obtain a Mach number value from a case run with Xifoam solver?? |
June 15, 2011, 04:00 |
Hi Foamers, I want to compute the Mach number from an case solved with XiFoam, but when I try to use the Mach utility from postProcessing velocityField library, but when I can do, the Mach utility give this error:
--> FOAM FATAL ERROR: Unknown basicPsiThermo type hhuMixtureThermo<homogeneousMixture<sutherlandTran sport<specieThermo<janafThermo<perfectGas>>>>> Valid basicPsiThermo types are: 11 ( ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<eConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>> ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>> hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>> hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>> hsPsiThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>> hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<hConstThermo<perfectGas>>>>> hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<janafThermo<perfectGas>>>>> ) From function basicPsiThermo::New(const fvMesh&) in file psiThermo/basicPsiThermo/newBasicPsiThermo.C at line 63. FOAM exiting I am looking for some help with this, I have tow ideas of how I can compute the Mach number: 1. I am thinking about changing the thermo type in the Mach utility, but i no have experience about programming in openFoam then I'm not very sure that I have to do?. 2. Extract the gamma value and then post computing Mach with the post-processing value of U and T, but I don't know where I have modify to extract the gamma value? computing the Mach number from:: M=U/sqrt(gamma*R*T) If anyone can orient me by the right way to do that, I was very thankful. best regards Felipe
Felipe G |
Isentropic Mach number definition | Turbomachine | CFX | 3 | August 16, 2023 06:52 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
Mach number Vs Convergence trend | saisanthoshm88 | CFX | 15 | January 13, 2011 01:59 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
