June 1, 2011, 09:56 |
Using incident radiation (G) in the solver
#1 | |
Mostafa Moghaddami
Rep Power: 17 |
Dear all,
I have some problems while generating a new solver base on the icoFOAM in OpenFOAM 1.7.0. At first, I have added the radiation model and two species transport equations (YH2O2 and YOHr) to the icoFOAM. Up to this step the solver worked correctly and provided reasonable results. Then I wanted to use incident radiation (G or G_) as a part of the source term of the species transport equations. But I got this error: Quote:
I wonder if there is anyway to use the incident radiation (G) as a parameter in my solver? The files of the solver are attached. Any help would be appreciated. Regards Mostafa |
May 1, 2018, 05:51 |
Dear Mostaf,
I meet samiliar problem like you. I want to use incident radiaton in my solver. But it is private scalarfield. Have you solved your problem? Chengan |
May 2, 2018, 09:10 |
Hello everyone,
I want to use incident radiation 'G' in my solver, which is in the attachement. In c++ code, it writes Code:
class fvDOM : public radiationModel { // Private data //- Incident radiation [W/m2] volScalarField G_; Code:
//- Const access to incident radiation field inline const volScalarField& G() const; Best regards Chengan |
May 21, 2019, 05:44 |
Michael Alletto
Rep Power: 16 |
Maybe the reply is a bit late but one can access a field present in memory by the following command:
const volScalarField& G_ = U.mesh().lookupObject<volScalarField>("G"); it gives you constant access to the desired field (obviously it cannot be modified) Best Michael |
May 26, 2019, 21:51 |
Hello Michael,
Thank you for your reply. Best regards Chengan |
incident radiation, modeling |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM Running, Solving & CFD | 17 | December 3, 2014 20:41 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 19:06 |
Question about radiation | Flying | CFX | 0 | January 12, 2005 21:32 |
radiation source-modeling people in room? | CFX5.7User | CFX | 0 | November 10, 2004 15:32 |
