Rep Power: 14 ![]() |
I am trying to understand the way Ax=b is solved in parallel across the processors.
The original mesh is comprised of 5 cells. The original matrix A without any decomposition is: -4 0 4 0 0 0 -3 0 0 3 4 0 -8 9 0 0 0 9 -6 5 0 3 0 5 -7 After using decomposePar utility the matrix A is decomposed in two smaller matrices as follows: First matrix ======== -3 0 3 0 -6 5 3 5 -7 Second Matrix ========== -4 4 4 8 When PCG solver is invoked, each process solves Ax=b independently and exchanges some information with other process to ensure correctness. My queries are as follows: 1. What is being exchanged? I see that in every iteration during Amul, some parts of vector pA is being sent to neighboring process. The neighboring process receives pA and performs additional computation to rectify wA. wA[] -= coeffs[] * pA_received[]; 2. Where do the coefficients come from? What's the significance of coeffs? 3. How does subtracting "coeffs[] * pA_received[]" from wA[] leads to the correct solution mathematically? Thanks in Advance. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Saving *.cas and *.dat from parallel version | Pfalcon | ANSYS | 1 | August 15, 2009 08:18 |
Saving *.cas and *.dat from Fluent parallel version | Pfalcon | FLUENT | 2 | August 14, 2009 14:57 |
UDF in parallel version of fluent | yobee | FLUENT | 2 | August 5, 2004 00:36 |
Parallel version of SIP ? | Ravikanth Avancha | Main CFD Forum | 1 | March 19, 1999 14:21 |
