March 3, 2011, 06:53 |
create an output file only at the endTime
Cyprien
Rep Power: 18 |
Hi!
I would like to create an output file at my last time step. I wondered if an command similar to Code:
if (runTime.outputTime()) { logFile << balbalbalblalba << endl; } Any help would be appreciated. Best regards, Cyp |
March 3, 2011, 12:18 |
David Gaden
Rep Power: 22 |
I believe you're looking for:
if (runTime.end()) |
March 3, 2011, 12:29 |
Cyprien
Rep Power: 18 |
Hi Marupio!
Thank you for your answer. I tried your suggestion but nothing is written inside my output file... |
March 4, 2011, 05:15 |
Anton Kidess
Rep Power: 30 |
You could also put your write command behind the time loop:
while (runTime.run()) { [...] } logfile << STUFF; |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 21:51 |
