fields + dimensions
Old   February 28, 2011, 22:29
Default fields + dimensions
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi all, I'm working in a solver and facing some problems at the time of deciding in how to implement the continuum formulation. Until I've read all important field in solver like, U, p, alpha, etc. are read from disk with dimensions and are used this way. Constants read from dictionaries have dimensions too.
My problems arise when I have to do some temporal calculus because I want to keep the dimensions in scalar and vectorFields. I'm using vol*Field to do so, but this kind of object have boundaries, which often are not necessary, because I'm doing calculus only with the internalField. When I use this fields as denominators the problem is that generates an error because the zero values of boundaries.
1. Is there a way to circumvent this issue?
2. Is normal to use vol*Fields to do this temporal calculus or is better to use non-dimensional objects or another kind of class?
Thanks in advance.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   March 1, 2011, 07:52
Nima Samkhaniani
nimasam is on a distinguished road
ur question is not clear at least for me
however for example if alpha is vol scalar field then
scalarField alphaInternal= alpha.internalField();
nimasam is offline   Reply With Quote
Old   March 1, 2011, 12:57
Yes this is an option, but it does not preserve the units, so you have to do all calculations without units.
Regards.
Research Scientist
Old   March 7, 2011, 13:47
Ivor Clifford
cliffoi is on a distinguished road
You can use DimensionedFields to preserve the dimension checking, i.e.
DimensionedField<scalar, fvMesh>& alphai = alpha;
cliffoi is offline   Reply With Quote
Dimensions ! T.D. OpenFOAM Running, Solving & CFD 4 September 24, 2010 15:26
Missing fields in reconstructPar flowris OpenFOAM 1 July 9, 2010 03:48
temperature / enthalpy fields depending on type of fvPatchField astein OpenFOAM Programming & Development 0 June 28, 2010 08:10
domainIntegrate, dieselFoam and Lagrangian Fields mturcios777 OpenFOAM 0 May 14, 2010 16:16
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
