June 25, 2018, 05:06 |
#101 | |
In any case, follow guys from ISP RAS (Moscow) https://github.com/unicfdlab Best wishes!
practice makes perfect |
August 24, 2018, 05:08 |
Could not find rho
#102 |
HBR
Rep Power: 8 |
Dear All,
First of all I would like to thank the great labour that Skeptik and his group are doing concerning to aeroacoustics. This is my very first post in this Forum, and I am pretty informed about how to manage common errors that appeared along this thread and others... but specifically this, I can not solve it by myself. I'm using the library libAcoustics.so during pisoFoam under OF4.1 in a very simple case that runs perfectly without using the library. What is more, I use also other libraries to, for example, calculate the force coefficients of lift/drag. The source of this error comes from nowhere but from any misuse of this library. The error I find is the following: Code:
Starting time loop forces CurleAnalogy1: Not including porosity effects Curle CurleAnalogy1: Not including porosity effects Reading analogy settings Time = 0.0001 Courant Number mean: 0.004787024 max: 0.1638222 smoothSolver: Solving for Ux, Initial residual = 0.0002232178, Final residual = 2.606655e-09, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0004308772, Final residual = 1.203743e-08, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0001465603, Final residual = 4.982442e-09, No Iterations 2 GAMG: Solving for p, Initial residual = 0.871151, Final residual = 0.04331954, No Iterations 2 time step continuity errors : sum local = 1.586758e-08, global = -1.57957e-10, cumulative = -1.57957e-10 GAMG: Solving for p, Initial residual = 0.04690876, Final residual = 0.001487216, No Iterations 3 time step continuity errors : sum local = 1.265232e-09, global = -8.444425e-11, cumulative = -2.424012e-10 GAMG: Solving for p, Initial residual = 0.006935179, Final residual = 7.817335e-07, No Iterations 14 time step continuity errors : sum local = 6.804893e-13, global = -1.056938e-14, cumulative = -2.424118e-10 smoothSolver: Solving for nuTilda, Initial residual = 0.001147876, Final residual = 1.686137e-08, No Iterations 2 ExecutionTime = 3.24 s ClockTime = 3 s [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] [3] [3] [3] --> FOAM FATAL ERROR: [3] Could not find rho [3] [4] Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ CurleAnalogy1 { functionObjectLibs ("libAcoustics.so"); type Curle; log true;//Logging info probeFrequency 1; patches ("sphere"); order second; timeStart 0; timeEnd 0.25; c0 341;//Velocity of sound in air dRef 4;//Domain ref for 2D computations pName p; //Pressure variable name rhoName rhoInf;//rho;//none rhoInf 1.0; pInf 0.0; CofR (0 0 0); //origin observers { probeA { position (5.0 0.0 0.0); pRef 0.0; fftFreq 1024; } probeB { position (0.0 2.5 0.0); pRef 0.0; fftFreq 1024; } } } // ************************************************************************* // 1) rho 2) none and regarding rhoInf 1) 1 2) Different value I have also tried to use/don't use the forces library unsuccessfully. Thank you all for your time, and I am sorry if this question has got an obvious answer. Have a nice day. Best regards, HBR Last edited by landau; August 28, 2018 at 05:07. |
January 6, 2019, 12:16 |
#103 | |
Sam
Rep Power: 8 |
Hello skeptik! Thank you very much for the development of libAcoustics! I have a few concerns: I am currently trying to compute the noise of a rotating propeller using fw-h. I wanted to use a faceZone i created around the propeller as the control fw-h surface, but the functionObject only accepts patches? I would like to know if the library can be updated to accept faceZones also. Also, it would be awesome if the probeFrequency would be modified to accept actual dt independent of the simulation timestep instead of 1. I tried to get the library to work with openfoam v1712, but i got a slew of errors during compilation errors. Are there any plans to extend the compatibility of these libraries to other versions? Again, thanks for working on libAcoustics! |
March 27, 2019, 15:55 |
#104 |
Albert
Dear all,
Thank you very much for the development of libAcoustics! I want to use it to calculate a 3D HVAC car System. What solver would you use for the calculation? I think a rhoPimpleFoam would be a good choice. Are there recommendations on what is better or makes more sense to use in my case? Thank you very much! |
October 31, 2019, 22:07 |
#105 |
Brett
Rep Power: 14 |
March 17, 2020, 06:16 |
with which equations?
#106 |
niewiemnic
Rep Power: 8 |
March 17, 2020, 12:34 |
#107 |
Alireza Maleki
Rep Power: 9 |
Hi
I do not think so. Using LEE to simulate the propagation of acoustic signals is much complicated and even the Ansys software does not use this method. I far as I know, this library uses integral surface methods to simulate the acoustic signals. Integral surface methods, like Farassat or Kirchhoff method, use a data surface to simulate the signal. I hope it would be helpful |
May 4, 2020, 14:18 |
digitef-dev-1912?
#108 |
niewiemnic
Rep Power: 8 |
I want to use this code https://github.com/unicfdlab/libAcoustics but does anybody know where can I find digitef-dev-1912? "OpenFOAM+ v.1912 is in the digitef-dev-1912 branch of the repository" |
May 29, 2020, 09:11 |
#109 |
Mustafa
Rep Power: 11 |
@spalartallmaras just click on branch on the left and in the dropdown select the 1912 repo instead of the master
February 24, 2021, 18:36 |
#110 | |
Guanjiang Chen
Rep Power: 6 |
Could you please share the OFW-Seoul-Kraposhin-AcousticTrack-5 pdf with me? I search it but don't find it. Thanks, Guanjiang |
February 24, 2021, 19:50 |
#111 | |
Guanjiang Chen
Rep Power: 6 |
This post may be helpful. how to use acoustic lib in openfoam Regards, Guanjiang Last edited by guanjiang.chen; February 26, 2021 at 18:21. |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
Running Problem using Openfoam solver | cfd_staruser | OpenFOAM | 5 | August 14, 2009 03:28 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 22:07 |
