gamma-ReTheta turbulence model for predicting transitional flows |
December 4, 2018, 21:45 |
#121 | |
kevin
Rep Power: 7 |
u.JPG k.JPG ReThetat.JPG |
December 5, 2018, 10:30 |
#122 |
Klaus
Rep Power: 22 |
Hi Kevin,
What airfoil do you have in mind? NACA0015.... I assume you're using an o-mesh but where's the inlet in your definitions?! What are your mesh parameters incl. y+, #cells along the surface (about 300?), #cells in z-direction (about 140?)? Here you can calculate your case specific turbulence properties: https://www.cfd-online.com/Tools/turbulence.php Please post your boundary file from the constant/polyMesh directory. Klaus |
December 9, 2018, 21:20 |
#123 | |
kevin
Rep Power: 7 |
Thank you for your reply. My calculated airfoil is DU-93-W-210. I use icem to generated a C-H type mesh, it was realized as follows (1) generate a 2d airfoil unstructured mesh in the x, y directions (2) extrude the mesh in the z direction. Since openfoam only accept the 3d unstructured mesh. For the inlet, it is a line in the 2d mesh. So, I delete in in the 3d mesh after extruding. Is that right? Please find the boundary information in the attached file. Thank you. boundary.JPG |
August 30, 2022, 11:50 |
Wmake
#124 | |
I did not understand what you said. |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
RSM & Transitional Flows!!! | Erika | FLUENT | 0 | March 31, 2006 10:56 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 13:19 |
turbulent separated flows | Yin | Fidelity CFD | 9 | February 19, 2003 11:50 |
