gamma-ReTheta turbulence model for predicting transitional flows |
June 9, 2016, 07:41 |
#81 |
Rep Power: 10 |
--> FOAM Warning :
From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/tesisti/OpenFOAM/tesisti-2.3.1/platforms/linux64GccDPOpt/lib/libGammaReThetatSST.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE --> FOAM Warning : From function dlLibraryTable:pen(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libGammaReThetatSST.so" i'm using version 2.3.1 i have implemented with wmake libso and add libs ("libGammaReThetatSST.so"); in controlDict. This are my files in Make: Files gammaReThetatSST/gammaReThetatSST.C derivedFvPatchFields/ReThetatTildaInlet/ReThetatTildaInletFvPatchScalarField.C LIB = $(FOAM_USER_LIBBIN)/libGammaReThetatSST Options EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude LIB_LIBS = \ -lincompressibleTransportModels \ -lincompressibleTurbulenceModels \ -lturbulenceModels \ -lfiniteVolume \ -lmeshTools The original Options was without any library under LIB_LIBS = and I have had same error. Could you find error in Make please? |
June 9, 2016, 07:45 |
#82 |
Artur
Rep Power: 20 |
Are you sure it compiled correctly? Otherwise the issue could be that you usually need to include both the custom library and libOpenFOAM.so so that all the environment variables etc. get set up properly, like so: Code:
libs ("libgammaReThetatSSTModel.so" "libOpenFOAM.so"); A |
June 9, 2016, 08:13 |
#83 |
Rep Power: 10 |
Sorry Artur but doesn't work with your suggest. Now I have recompiled it and this compare me:
tesisti@ime042:~/OpenFOAM/tesisti-2.3.1/gammaReThetatSST-master/src/turbulenceModels/incompressible/RAS> wmake libso wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file gammaReThetatSST/gammaReThetatSST.C Making dependency list for source file derivedFvPatchFields/ReThetatTildaInlet/ReThetatTildaInletFvPatchScalarField.C SOURCE=gammaReThetatSST/gammaReThetatSST.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/transportModels -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gammaReThetatSST.o SOURCE=derivedFvPatchFields/ReThetatTildaInlet/ReThetatTildaInletFvPatchScalarField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/transportModels -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/tesisti/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ReThetatTildaInletFvPatchScalarField.o '/home/tesisti/OpenFOAM/tesisti-2.3.1/platforms/linux64GccDPOpt/lib/libGammaReThetatSST.so' is up to date. tesisti@ime042:~/OpenFOAM/tesisti-2.3.1/gammaReThetatSST-master/src/turbulenceModels/incompressible/RAS> So seems that compilation is correct. |
June 9, 2016, 09:01 |
#84 |
Artur
Rep Power: 20 |
Yes, the compilation seems to work OK. The error you are getting is due to some sort of mix-up of library names, difficult to say for sure without diving into the code. My advice would be to see if the turbulence model actually gets used the way you intended (it should). If yes then you can probably ignore the warning or go through the code very carefully and make sure you are not re-defining any class or namespace names and stuff like that. You are not the only one with similar issues, if that's of any comfort:
http://www.cfd-online.com/Forums/ope...ed-symbol.html Good luck, A |
June 9, 2016, 09:25 |
#85 |
Rep Power: 10 |
Artur i have been able to resolve that error changing options like this:
EXE_INC = \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/transportModels \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude LIB_LIBS = \ -lincompressibleTurbulenceModel \ -lincompressibleRASModels \ -lfiniteVolume \ -lmeshTools And adding in controlDict these libraries: libs ( "libGammaReThetatSST.so" "libOpenFOAM.so" "libincompressibleTurbulenceModel.so" "libincompressibleRASModels.so" ); But now controlling residuals I have noted a strange thing: gamma's residual is always 0 I have set gamma at farfield to fixedValue 0 and at walls to zeroGradient...could be this the problem? |
June 9, 2016, 09:33 |
#86 |
Artur
Rep Power: 20 |
Great, thanks for sharing the solution.
As for your question, to be perfectly honest I haven't used the model for over a year now but looking at my old T3 case I see that I used: gamma: fV 1 at the inlet, zeroGradient/symmetryPlane everywhere else ReThetaTilda: fV 1.574098e+02 at the inlet (estimated using Langtry's thesis I'm sure, don't remember details), zeroGradient/symmetryPlane elsewhere An yes, I expect residual of 0 is a problem, do any solver iterations run on the equation at all? |
June 9, 2016, 09:41 |
#87 |
Rep Power: 10 |
This is an output of iterations of solvers:
DILUPBiCG: Solving for Ux, Initial residual = 0.00101384, Final residual = 2.53875e-06, No Iterations 5 DILUPBiCG: Solving for Uy, Initial residual = 0.00372243, Final residual = 8.34491e-06, No Iterations 6 DICPCG: Solving for p, Initial residual = 0.158877, Final residual = 0.00157672, No Iterations 142 DICPCG: Solving for p, Initial residual = 0.00953748, Final residual = 9.4226e-05, No Iterations 242 DICPCG: Solving for p, Initial residual = 0.000902539, Final residual = 8.72116e-06, No Iterations 564 DICPCG: Solving for p, Initial residual = 0.000122209, Final residual = 1.19077e-06, No Iterations 196 time step continuity errors : sum local = 1.4866e-08, global = 3.47018e-16, cumulative = 3.4095e-13 DILUPBiCG: Solving for omega, Initial residual = 8.75562e-06, Final residual = 8.75562e-06, No Iterations 0 DILUPBiCG: Solving for k, Initial residual = 5.05121e-05, Final residual = 4.86721e-06, No Iterations 2 DILUPBiCG: Solving for ReThetatTilda, Initial residual = 0.00266045, Final residual = 0.000147846, No Iterations 2 DILUPBiCG: Solving for gamma, Initial residual = 0, Final residual = 0, No Iterations 0 In addition to gamma is worrying number of iterations of pressure. |
June 9, 2016, 09:48 |
#88 |
Artur
Rep Power: 20 |
Yup, definitely something fishy going on. Here's the setup I used in the past back when OF was at 2.2.2. This was based on one of the original test cases posted by Felix:
https://www.dropbox.com/s/ly0scvqgdh...3A.tar.gz?dl=0 Maybe have a look and see if there are any major differences between this and your setups. |
June 9, 2016, 10:08 |
#89 |
Rep Power: 10 |
Thank you Artur!
In my case have a O-grid so i have farfield. In this case is corrected set for ReThetatTilda bc ReThetatTildaInlet or i have set freestream? Same thing for Gamma, now at farfield i have set fV, i have set freestream? |
June 9, 2016, 10:11 |
#90 |
Artur
Rep Power: 20 |
Yes, in the case of an O-grid I'd go for freeStream with similar values to mine (check out Langtry's thesis and lit review for how to estimate inlet conditions); optionally you could use inletOutlet since that will act in a similar fashion in this context, I expect.
June 9, 2016, 10:55 |
#91 |
Rep Power: 10 |
About value of ReThetatTilda at farfield i have found a document in which there are equations to find Rethetat to page 16 from 3.24 to 3.28 bit isn't specified how find ReThetatTilda. Can I use the value obtained from these equations for ReThetatTilda?
June 9, 2016, 11:02 |
#92 |
Artur
Rep Power: 20 |
I'll be perfectly honest, I don't remember how exactly this has to be done, sorry. Apart from Langtry's thesis I think this paper is quite useful to get your head around it:
http://cfd.mace.manchester.ac.uk/twi...a-re-theta.pdf If I recall correctly, you have to assume a value for the pressure gradient coefficient and then compute one of the F(lambda) functions. This can then be used to yield ReThetaTilda value. At least this is what I appear to have done when I was working on the T3 case. Sadly I didn't make detailed notes so can't point you to the exact equations, they must be in the two references I shared though. All the best, A |
June 9, 2016, 11:14 |
#93 |
Rep Power: 10 |
So you are telling me that i have to use the last two equations in appendix 24 and 25? If they are, they are same that i have used to found Rethetat
June 9, 2016, 11:30 |
#94 |
Rep Power: 10 |
And if I used for ReThetatTilda the bc, implemented with the turbulence model, RethetatTildaInlet, I'd avoid to calculate it. But the only doubt is if this bc is correct for farfield in a O-grid
June 9, 2016, 11:33 |
#95 | ||||
Artur
Rep Power: 20 |
From Langry's thesis, pp 42, below eq. 3.13:
On the same page, Quote:
Moving on to ReTheta, on pp 45, last paragraph: Quote:
Mind you, I could be misinterpreting this so use at your own risk A |
June 9, 2016, 11:36 |
#96 | |
Artur
Rep Power: 20 |
A |
June 9, 2016, 11:52 |
#97 |
Rep Power: 10 |
I really appreciate your help Artur. Now i'm going to try with ReThetatTildaInlet at farfield and using other bc you have suggested me, then I will notice about my results.
Best Regards! |
July 1, 2016, 05:13 |
#98 | |
Rep Power: 10 |
July 1, 2016, 05:52 |
#99 |
Artur
Rep Power: 20 |
Well spotted, I don't know why they used zeroGradient. I tend to use fixedValue 0 on the wall for k and zeroGradient for omega with the kkl model built-in OpenFOAM as well as for the gamma-Re-theta model.
July 1, 2016, 06:09 |
#100 |
Rep Power: 10 |
Mmm, for omega at wall i'm using fixedValue ω = 6ν/(βy2) like in the paper. In my past simulation I used for wall k 1e-12 but my results were wrong and I had a flux without separation because my Cl was growing instead stall should occurs.
Currently I'm performing a simulation with k zeroGradient and it seems going better at the moment |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 04:20 |
RSM & Transitional Flows!!! | Erika | FLUENT | 0 | March 31, 2006 11:56 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 14:19 |
turbulent separated flows | Yin | Fidelity CFD | 9 | February 19, 2003 12:50 |
