varying cp with temperature .
Like Tree1Likes
Old   February 22, 2011, 08:44
akidess's Avatar
Anton Kidess
It means that you are trying to solve for two variables within one equation.
Old   February 22, 2011, 08:49
Balkrishna Patankar
balkrishna is on a distinguished road
Thanks. That is clear . However a formulation like below ,
fvScalarMatrix hEqn
        fvm::ddt(rho, h)
      + fvm::div(phi, h)
      - fvm::laplacian(turbulence->alphaEff(), h)
        DpDt
assumes constant k . How does one program without the constant k assumption ?
balkrishna is offline   Reply With Quote
Old   July 18, 2013, 06:12
Rohith
RaghavendraRohith is on a distinguished road
Hi BalKrishna
Have you found the solution for this problem. How can some body solve 2 variables here.
Regards
Rohith
RaghavendraRohith is offline   Reply With Quote
Old   June 16, 2015, 11:10
Sandip Wadekar
wadekar is on a distinguished road
Dear sir,
I am getting the error after using Foam::tanh(...)
The error is: call of overloaded ‘tanh(const int&)’ is ambiguous
c[ignCell] =1-Foam::tanh(ignSite.cells()[icelli]);
The code is:
forAll(ign.sites(), i)
const ignitionSite& ignSite = ign.sites()[i];
if (ignSite.igniting())
forAll(ignSite.cells(), icelli)
label ignCell = ignSite.cells()[icelli];
wadekar is offline   Reply With Quote
Old   June 16, 2015, 11:18
Sandip Wadekar
Dear sir,
The code is:
Old   June 16, 2015, 11:41
Rohith
Hi Sandip,
I hope tanh in openfoam takes only a value i.e if you define a dimensionedScalar then please define its value. See that there exists no Fields. I See Ignsites is a constant, i am not sure. If you can define it so.
Best Regards,
Rohith
Old   June 16, 2015, 12:09
Sandip Wadekar
Thanks Raghavendra
I have tried with the interger value 5,
but still i am getting the same error:
call of overloaded ‘tanh(int)’ is ambiguous
c[ignCell] =Foam::tanh(5);
Old   June 18, 2015, 04:32
Sandip Wadekar
Hello friends,
I am compile the below mention code and i am getting the error
error: ‘distance’ was not declared in this scope
c = Foam::tanh[distance];
pointField meshPoints(mesh.points());
       label i(0);
       forAll( meshPoints, kk)
        vector curPoint = meshPoints[kk];
        vector distance = curPoint - vector(0, 0, 0);
        i++;
    scalar dis = mag(distance);
        Info<< "distance = " << dis << endl;
      Info << i << "  Points are changed" << endl;
    volScalarField  c = Foam::tanh[distance];
Old   June 30, 2016, 18:32
elham usefi
elham usefi is on a distinguished road
Originally Posted by balkrishna View Post
When i rewrite the enthalpy equation as :
fvScalarMatrix hEqn
           fvm::ddt(rho, h)
           + fvm::div(phi, h)
            fvm::laplacian(k,T)
           + DpDt + heatSource
//In the above , k is thermal conductivity , T is temperature , h is enthalpy .
I get the following error :
incompatible fields for operation
    [h] == [T]
    From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
    in file /home/ifmg/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvMatrix.C at line 1181.
How to overcome it ?
Hi i knw this post is old but i need help on this problem
in my case Cp varies in different locations, so I need to write energy equation with enthalpy. I wrote it like this:
   fvScalarMatrix EEqn
        fvm::div(phi, E)
      - fvm::laplacian(k_n/cp, E)
        fvOptions(rho,E)
    EEqn.relax();
    fvOptions.constrain(EEqn);
    EEqn.solve();
    fvOptions.correct(E);
    T=E/cp;
    rhok = (1.0 - beta*(T - TRef));
but I got unrealistic solution that diverges!
can u help me?
elham usefi is offline   Reply With Quote
Old   July 1, 2016, 02:09
Rohith
The only error i see is that you have defined enthalpy as E=cp*T But it is
deltaE = cp*deltaT.
Hope it helps
Regards,
Rohith
Old   July 3, 2016, 19:12
elham usefi
Originally Posted by RaghavendraRohith View Post
deltaE = cp*deltaT.
Hope it helps
Regards,
Rohith
HI!
thank u for ur response but I didnt get it! if we replace E with cp*T in
        fvm::div(phi, E)
        fvOptions(rho,E)
the result would be like:
        fvm::div(phiCp, T)
      - fvm::laplacian(k_n, T)
        fvOptions(rhoCp,T)
so isnt EEqn correct?
actually first I tried TEqn like this:
        fvm::div(phiCp, T)
        fvOptions(rhoCp,T)
but I didnt get correct results!
but when I assume that cp is constant! like this:
        cp*fvm::div(phi, T)
        fvOptions(rhoCp,T)
I get good results! although the variation of cp is not very significant!
so I tried EEqn
density, property, specific heat, temperature
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
udf for varying inlet temperature aravind FLUENT 0 October 27, 2008 11:08
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
