December 11, 2010, 08:50 |
Rotating square on icoFoam cavity
Hi Foamers,
I inserted an obstacle in the icoFoam/cavity case and to see what happens when it rotates I've included dynamic mesh effects on icoFoam. The thing is: The square rotates correctly, but the problem is that the mesh rotates with it, and that produces a bad mesh quality (severe non-orthogonality). I would like the mesh to just stretch and contract as the square rotates. I mean, I don't want the points attached to the square to rotate. To better explain: When you look at the mesh in the wireframe form on paraView, I want the horizontal wires to keep their y(vertical) position and move (expand or contract) horizontally as the square rotates, and I want the vertical wires to keep their x (horizontal) position and move (expand or contract) vertically as the square rotates. I attach an image to show my resulting mesh behavior, which is what I don't want. How can this be achieved? Attach/detach? Sliding interface? Thanks and regards! All the best |
January 14, 2011, 10:23 |
Well, what I finally did is rotate a small angle and re-blockMesh with the position of the new points. Then interpolated results to the new mesh and rotate a bit more and repeat the process several times.
I used moveDynamicMesh to check mesh validity, to assure the rotated angle at each part does not destroy the mesh. Any better ideas? Thanks and regards! |
dynamic mesh, icofoam |
Why icoFoam solver results are not true for cavity (10000>Re>5000) ? | maysmech | OpenFOAM | 9 | February 4, 2020 10:42 |
solidification in a square cavity | arou | FLUENT | 2 | September 22, 2010 09:26 |
natural convection in square cavity | Dhileep | Main CFD Forum | 0 | January 11, 2009 11:29 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
radiation problem for square cavity using fluent | john | Main CFD Forum | 0 | September 30, 2005 08:40 |
