Edit .C file
Old   November 28, 2010, 07:54
Question Edit .C file
Usit McCarra
McCarra is on a distinguished road
Hello everybody,
How can I edit a .C file? My gedit says [Read-Only].
thanks
McCarra is offline   Reply With Quote
Old   November 28, 2010, 11:09
Retired Super Moderator
Bruno Santos
Greetings José,
My guess is that you are using Ubuntu 10.04 or 10.10 and have installed the Debian packages of OpenFOAM. If this is the case, the OpenFOAM source code is installed in /opt, which is a system folder and can only be edited using superuser powers, i.e. using sudo or using "su -" to change to the user root.
The proper way of editing OpenFOAM code is to copy the desired library or application into your user area, modifying it for building it in your user space and then doing the desired modifications. See this tutorial: How to add temperature to icoFoam
Also, you can see in the official user guide, this section: Compiling applications and libraries
Either that, or build OpenFOAM from source in your own user space: Source Pack Installation
Best regards,
Bruno
code, edit
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 14:22
