fixedMeanValue "namespace" error
Old   November 10, 2010, 05:04
Unhappy fixedMeanValue "namespace" error
siddharameshwara is on a distinguished road
Hi to all,
I tried to add fixed MeanValue boundary condition to my cavitatingFoam but when i execute it using wmake it is showing the following error
fixedMeanValueFvPatchField.H:41: error: ‘namespace’ definition is not allowed here
Can anybody help me in this regard
Thanks
siddharameshwara is offline   Reply With Quote
Old   December 11, 2010, 08:38
Usit McCarra
McCarra is on a distinguished road
If I'm not mistaken, you should apply the boundary conditions on the 0 folder of your case. It makes no sense to compile boundary conditions since they are set at "user level".
Which is the case you are running? Is it a tutorial?
Depending on the parameter you are trying to set (U, p,...) there are different options of patchField types (fixedValue, fixedGradient, fixedNormalSlip...).
Regards
McCarra is offline   Reply With Quote
Old   December 13, 2010, 04:00
Smile
Regards
Hi dude,
I am using tutorial. But, now i solved the problem. I had some problem with permissions. Now everything is ok. Any how thanks for your reply,
Cheers.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 14:29
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user defined function cfduser CFX 0 April 29, 2006 11:58
