chtIcoMultiRegionFoam - Incompressible version of chtMultiRegionFoam. |
July 11, 2011, 10:11 |
#41 | ||
maddalena
Rep Power: 23 |
Hi Nicolas,
mad |
July 12, 2011, 05:34 |
#42 |
Nicolas
Rep Power: 15 |
Hi Maddalena,
I've just use the chtIcoMultiRegionFoam solver from the first post in this thread, with no modification. As it was run steady for solids, I thought I only had to change the fvSchemes and the controlDict. Seems that was too easy I hope you can enlighten me since I'm pretty new on CFD and OF. Nicolas |
July 12, 2011, 05:52 |
#43 | |
maddalena
Rep Power: 23 |
As the name says, chtIcoMultiRegionFoam is based on icoFoam. It means that the fluid part is solved in the same way of icoFoam. Thus one thing you can try is to take a icoFoam tutorial (cavity should be ok) and compare the unsteady and steady solution, the latter obtained changing fvSchemes, fvSolution and controlDict only, and adjusting BC if necessary. I guess the solver will complain... In that case, you have to modify chtIcoMultiRegionFoam throwing away all the ddt terms and changing the loops accordingly. A good point where to start is to reproduce the same changes there are between chtMultiRegionFoam and chtMultiRegionSimpleFoam, as I said before. mad PS: of course, I am not saying you have to do it for me: I need a steadyState version of this solver as well. I hope we can work together on it! |
July 13, 2011, 06:10 |
#44 |
Nicolas
Rep Power: 15 |
+1 for your PS
Can you check the solver in the attachment? I made a copy of chtIcoMultiRegionFoam; changed the names; commented the "ddt" terms in the equations; commented the "#include" with time, Pimple and piso; added the "readSIMPLEcontrols" from chtMultiRegionSimpleFoam; changed the PISO loop to a SIMPLE one. I hope I've forgotten nothing. Waiting for your feedback Regards |
July 13, 2011, 07:16 |
#45 |
maddalena
Rep Power: 23 |
Just give a fast look at it. I think you commented too much, especially on the fluid part. But give me some more time to go deeper.
mad |
July 20, 2011, 11:09 |
#46 |
Mirko Vukovic
Rep Power: 17 |
July 20, 2011, 11:52 |
#47 |
Fábio César Canesin
Rep Power: 16 |
Hi all,
You will not have success in creating a steady version in it definition. The energy exchange at the interface is done in an boundary update methodology.. segregated. The only thing could be done in an segregated approach is to use an fake transient with large time step (like the pimpleFoam solver). To create an trully steady state version of the solver one needs to make it fully coupled, like in an block coupling for velocity-pressure. |
July 21, 2011, 10:13 |
#48 | |
Mirko Vukovic
Rep Power: 17 |
August 8, 2011, 10:38 |
#49 |
Nicolas
Rep Power: 15 |
Hi Fábio,
As I'm preparing the oral following my training period, I'd like some pieces of information not to be trapped by easy questions... Just to be sure, can you confirm the next equations are solved in your chtIcoMultiRegionFoam? Solid: d(rho*Cp*T)/dt - grad.(K*grad(T)) = 0 Fluid: dU/dt + grad.(phi*U) - grad.(nu*grad(U)) + (source) = - grad(p) dT/dt + grad.(phi*T) - grad.(Kappaeff*grad(T)) = 0 grad.(rUA*grad(p)) = grad.(phi) I'm not very skilled in C++, nor in Of: I've got difficulties in converting the code in mathematical language. Moreover, I haven't understood what is the central coefficient rUA. Could you enlighten me? Thanks in advance, Nicolas |
August 8, 2011, 14:53 |
#50 |
Fábio César Canesin
Rep Power: 16 |
Nicolas,
You are almost right .. .just the last equation: grad(rAU*grad(p))= grad(phi) rAU = 1.0/UEqn().A() Look at doxygen what the .A() is: //- Return the central coefficient 00403 tmp<volScalarField> A() const; It is related with the PISO algorithm in OpenFOAM: refer to: http://openfoamwiki.net/index.php/Th...hm_in_OpenFOAM |
August 9, 2011, 08:08 |
#51 |
Nicolas
Rep Power: 15 |
There's something I don't understand.
Are they really gradients and not divergences, in the p-equation? Because in the file pEqn.H we have: Code:
fvScalarMatrix pEqn ( fvm::laplacian(rUA, p) == fvc::div(phi) ); Code:
fvScalarMatrix pEqn ( volVectorField temp = rUA*fvc::grad(p); fvm::grad(temp) == fvc::grad(phi) ); I'd seen the definition of rUA, but I've no idea of what the 'central coefficient' returned by the A() function is. I'm going to dig deeper in the PISO algorithm. Many thanks for your help, Nicolas |
July 17, 2013, 16:45 |
#52 |
Dear Fabio, Thank you for your contribution. Fabio and mad I wonder if you have been able to develop a code for incompressible steady turbulent flows, as it is the base characteristics for most of the heat transfer cases. Is this new solver (chtIcoMultiRegionFoam) appropriate for using turbulence models? All these aside, I can not understand one thing. Is it OK to use the compressible chtMultiRegionSimpleFoam solver for an incompressible case? as it has been used in here: planeWall2D ? Best wishes, Mojtaba
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
August 22, 2013, 06:17 |
#53 |
X Meng
Rep Power: 14 |
I am thinking about this as well...
August 26, 2013, 09:00 |
#54 |
X Meng
Rep Power: 14 |
Hi, I am trying to compile the application in Version 2.2.0, a fatal error occured as:
'directMappedPatchBase.H: No such file or directory'. Actually, I can't find this in this version. |
August 26, 2013, 09:10 |
#55 | |
Leonardo Honfi Camilo
Rep Power: 17 |
This is due to the fact that the directMapped patch was renamed in OF>=2.1 to just mapped. This patch is used by the conjugate boundary conditions so you should go to the following folder inside your solver: derivedFvPatchFields/solidWallMixedTemperatureCoupled search for every instance of directMapped* and change it to mapped* , you should do that for both the .C and .H file. PS: The * is just there to indicate that the patch name above may be part of a longer word. Last edited by lhcamilo; August 26, 2013 at 09:15. Reason: PS |
August 27, 2013, 06:14 |
#56 |
X Meng
Rep Power: 14 |
Hi, Camilo, thank you very much for your reply.
Now, my solver is compiled well. However, an error "hanging pointer, cannot dereference" occurs when 'adding to turbulence' for a very simple case. Still struggling for that.... |
August 27, 2013, 06:40 |
#57 |
Rep Power: 17 |
I have had those problems... they are more fun than a barrel full of monkeys.
In any case,my guess is that your problem is probably somewhere inside the fluid/createFluidFields.H folder or solid/createSolidFields.H , some variable is probably not properly declared , usually the type of field or information is wrong. These may be tricky to find and I had to spend more time than I care to admit understanding the purpose of each of these lines and variables in these folders (and the entire solver) to the point that I could re-write them from scratch (which I eventually did) for the particular set of cases I have been working on). I wish I could be more help but this is a very hands on type of problem, you can also add the following bit of code to check where exactly the breaking happens Code:
Info << "\n Check 1... \n"<<endl; GL |
August 27, 2013, 09:54 |
#58 |
X Meng
Rep Power: 14 |
Thank you!
I got it, the problem is my definition of transportModel. Thanks again!!! |
June 9, 2014, 04:14 |
double viscous term
#59 |
tmp<fvVectorMatrix> UEqn
( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) + turb.divDevReff(U) ); If you look the UEqn in the chtIcoMultiRegionFoam posted by Mr. Canesin (shown above), the viscous term appears twice. So the - fvm::laplacian(nu, U) or + turb.divDevReff(U) should be deleted ( I deleted the - fvm::laplacian(nu, U)). I compared the calculation results with the reference results shown below. http://www.sciencedirect.com/science...17931086900177 Both of them show good agreement |
July 2, 2014, 07:29 |
Dimension of phi are not correct
#60 |
Cyril
Rep Power: 12 |
Hello everyone!
I installed chtIcoMultiRegionFoam on the 2.3 version of OpenFoam. Because of the new version, I replaced ddtPhiCorr with ddtCorr in pEqn.H compile and ran the previous case but I got this error: Solving for fluid region fluid DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.02009576, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.98533956, Final residual = 0.011378115, No Iterations 1 DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 4.4231395e-09, No Iterations 5 max(T) [0 0 0 1 0 0 0] 400 --> FOAM FATAL ERROR: dimensions of phi are not correct From function EulerDdtScheme<Type>::fvcDdtPhiCorr in file finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C at line 602. It seems that something goes wrong with phi . What can I do to fix this error? Thank you Regards Cyril |
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | OpenFOAM | 10 | April 19, 2021 18:06 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
bubbleFoam validation case | balkrishna | OpenFOAM Running, Solving & CFD | 24 | August 30, 2010 04:37 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 20:55 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
