Orthotropic solid displacement
Old   November 4, 2010, 11:36
Default Orthotropic solid displacement
Daniel Chrastina
shpalman is on a distinguished road
Send a message via Yahoo to shpalman Send a message via Skype™ to shpalman
Hello all,
I'm trying to write a solver, loosely based on solidDisplacementFoam, which will work on orthotropic solids. The stiffness constants and the density are specified as fields (and there is also a misfit field f, since what I'm actually trying to do involves coherent interfaces between materials with different lattice constants).
Since the system is anisotropic I can't just calculate Lamé parameters, but since OpenFOAM can't handle the full fourth-rank 3x3 stiffness tensor I can't just write sigma = c : epsilon (where sigma is the stress tensor and epsilon is the strain tensor). However, since it's orthotropic I can work with vectors for the pressure and shear terms for both stress and strain, and two 3x3 tensors with the elastic constants in (for c_ij where i or j are 1, 2 or 3; and for c_kk where k is 4, 5 or 6).
rho * fvm::d2dt2(D) == fvc::div(sigma)
epsilon = 0.5*(fvc::grad(D) + fvc::grad(D)().T());
epsilonPressure.component(0)=epsilon.component(0)-f;
epsilonPressure.component(1)=epsilon.component(4)-f;
epsilonPressure.component(2)=epsilon.component(8)-f;
epsilonShear.component(0)=epsilon.component(3);
epsilonShear.component(1)=epsilon.component(2);
epsilonShear.component(2)=epsilon.component(1);
sigmaPressure = cPressure & epsilonPressure;
sigmaShear = cShear & epsilonShear;
sigma.component(0)=sigmaPressure.component(0);
sigma.component(4)=sigmaPressure.component(1);
sigma.component(8)=sigmaPressure.component(2);
sigma.component(5)=sigmaShear.component(0);
sigma.component(7)=sigmaShear.component(0);
sigma.component(2)=sigmaShear.component(1);
sigma.component(6)=sigmaShear.component(1);
sigma.component(1)=sigmaShear.component(2);
sigma.component(3)=sigmaShear.component(2);
I'm calculating the strain tensor from the displacement, setting up two strain vectors, getting two stress vectors from those via the stiffness tensors, and rebuilding the stress tensor which I'd like to put back on the right-hand side of the equation. But is it even possible to solve a system of equations like this, rather than having the spatial derivatives of D explicitly on the right-hand side?
I appreciate any feedback at all...
Best,
Danny.
shpalman is offline   Reply With Quote
heteroepitaxy, semiconductor, soliddisplacementfoam, strain
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
how to use Total Mesh Displacement for making a subject translating and rotating? snailstb CFX 3 September 16, 2009 05:06
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 08:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
