PStream/IPstream/OPstream class support for int64_t? |
November 1, 2010, 12:46 |
Allen Zhao
Rep Power: 17 |
I am using OpenFOAM-1.4.1-dev with gcc. But I have a need to pass int64_t type data using IPstream/OPstream class, and apparently, the PStream class does not support int64_t type ( at compilation time: Example: typedef int64_t INTEGER8; INTEGER8 masterData, slaveData; from master node: OPstream toSlave(slave); toSlave << (INTEGER8) masterData; On slave node: IPstream fromMaster(Pstream::masterNo()); fromMaster >> slaveData; gcc (with either -m32 or -m64) will give something like following: ../gtopenfoamLib/FoamCalls.cpp:181: error: ambiguous overload for âoperator>>â in âfromSlave >> objSlaveâ /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Istream.H:160: note: candidates are: Foam::Istream& Foam:operator>>(Foam::Istream&, Foam::IOstream& (*)(Foam::IOstream&)) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Istream.H:154: note: Foam::Istream& Foam:operator>>(Foam::Istream&, Foam::Istream& (*)(Foam::Istream&)) <near match> ../gtopenfoamLib/FoamCalls.cpp:182: warning: use of old-style cast ../gtopenfoamLib/FoamCalls.cpp:182: warning: use of old-style cast ../gtopenfoamLib/FoamCalls.cpp:189: warning: use of old-style cast ../gtopenfoamLib/FoamCalls.cpp:189: error: ambiguous overload for âoperator<<â in âtoMaster << (long int)lpFoamObjectRefâ /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/uint.H:58: note: candidates are: Foam::Ostream& Foam::operator<<(Foam::Ostream&, unsigned int) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Ostream.H:203: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, Foam::IOstream& (*)(Foam::IOstream&)) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Ostream.H:197: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, Foam::Ostream& (*)(Foam::Ostream&)) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/IOstream.H:537: note: Foam::IOstream& Foam::operator<<(Foam::IOstream&, Foam::IOstream& (*)(Foam::IOstream&)) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Scalar.H:260: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, Foam::doubleScalar) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/Scalar.H:260: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, Foam::floatScalar) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/bool.H:51: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, bool) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/int.H:59: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, int) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/string.H:196: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, const std::string&) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/char.H:52: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, const char*) <near match> /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/char.H:51: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, char) /Apps/openfoam/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/IOstream.H:99: note: Foam::Ostream& Foam::operator<<(Foam::Ostream&, const Foam::IOstream::streamFormat&) <near match> ../gtopenfoamLib/FoamCalls.cpp:200: warning: use of old-style cast So apparently, we have some issues with pass 64-bit integer with MPI. Here is my question: What is the quickest way to patch the PStream class to enable the int64_t type? Any pointer will help. |
November 1, 2010, 17:18 |
Allen Zhao
Rep Power: 17 |
My current work around is following function:
/*-----------------------------------------------/ OpenFOAM's PStream does not support int64_t data type. Following 3 functions are utility functions to divide INTEGER8 to 2 INTERGER or conbine 2 INTEGER data to INTEGER8 data. ------------------------------------------------*/ static INTEGER HiInteger8(INTEGER8 lNnumber) { return (INTEGER) ((lNnumber >> 32) & 0xFFFFFFFF); } static INTEGER LoInteger8(INTEGER8 lNnumber) { return (INTEGER) (lNnumber & 0xFFFFFFFF); } static INTEGER8 ToInteger8(INTEGER nHigh, INTEGER nLow) { return ((((INTEGER8)nHigh) << 32) | nLow); } But it will be ideal is PStream class can handle it by default. |
int64_t, ipstream, opstream, pstream |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 08:21 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
About UList and List class | leosding | OpenFOAM Running, Solving & CFD | 1 | December 2, 2005 00:52 |
