low-level use of fvMatrix
Old   September 19, 2010, 10:27
Default low-level use of fvMatrix
Corinna
Conny_T is on a distinguished road
Hi everybody,
is the fvMatrix class general enough to represent equation systems that do not only come from finite volume discretization? The reason for my question is the following. For some internal cells of a finite volume problem I want to remove the standard discretization and instead impose a condition like "the sum of the cell values y_k1...y_kL is equal to 1". Basically I must be able to replace any row i in a fvMatrix with an arbitrary linear combination (ai1...aiN)*(y1...yN)=bi.
Related to this is my second question. The right hand side "bi" above may be coupled to another equation system. Is it possible to increase the number of rows and columns in an fvMatrix to add additional variables and constraints to the system?
Please let me know if I can find examples somewhere how to
1) modify individual rows
2) extend an fvMatrix with additional rows and columns
The background of my question is to couple minimization using lagrange multipliers with the finite volume discretization, but even though I know that there are other means to do this, I'd need to know how to modify the coefficients of an fvMatrix. I only found the diag(),lower(),upper() and source() methods, but I don't understand how to combine cell values that are not direct neighbours, not to mention additional constraints that are not at all represented by any cell value.
Thanks
Conny
Conny_T is offline   Reply With Quote
Old   September 20, 2010, 10:31
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Conny
Thanks
Conny
fvMatrix inherits from lduMatrix
00072 /*---------------------------------------------------------------------------*\
00073                            Class lduMatrix Declaration
00074 \*---------------------------------------------------------------------------*/
00075
00076 class lduMatrix
00077 {
00078     // private data
00079
00080         //- LDU mesh reference
00081         const lduMesh& lduMesh_;
00082
00083         //- Coefficients (not including interfaces)
00084         scalarField *lowerPtr_, *diagPtr_, *upperPtr_;
the only info you have stored in the class is that is related with matrix non-zero coefficients,
their position is given by uppperAddr and lowerAddr arrays. These arrays
only have information from shared faces, then if you want to add some other
coefficients info won't be consistent with the mesh. Maybe you can use the Foam::Matrix
class which is intended for full matrices storage or code your own generic
sparse matrix class.
Hope this info be useful.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
Last edited by santiagomarquezd; September 20, 2010 at 10:33. Reason: Wrong quoting tag
santiagomarquezd is offline   Reply With Quote
Old   September 20, 2010, 15:41
Corinna
Yes, your info is helpful. So I give up OpenFOAM, because there is no solution to my problem.
Using the Matrix class is out of the question for any but the smallest problems.
Using more powerful sparse matrix packages comes close to rewriting everything except for lduMatrix.
I also had a look at cyclicFvPatchField and found that it does not actually couple non-adjacent boundary patches, but instead copies the values around in each iteration. Maybe this is another hint that lduMatrix cannot be used for advanced cell couplings?
Thanks
Conny
Old   September 20, 2010, 15:54
Hmm, I don' know anything about the part of coupling, but respect of the matrices, the storing method is useful but it is necessary to have extra Addr arrays in order to be capable to address more coefficients than only which corresponds to shared faces. On the other hand FOAM is specially designed to avoid second neighbors, then changing this paradigm maybe force you to re-implement a lot of other things. At this point more experienced users/developers must give their opinions.
Good luck with your job.
Santiago.
Research Scientist
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 20:00
[snappyHexMesh] snappyHexMesh - Refinement Level andrea.pasquali OpenFOAM Meshing & Mesh Conversion 5 February 8, 2010 04:08
Relaxation factors Vidya Raja FLUENT 7 September 26, 2006 21:00
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Is there any program for low noise level ventilator design? Ahlo Main CFD Forum 0 September 17, 1998 00:39
