#21 |
Anton Kidess
Rep Power: 30 ![]() |
I guess that if you'd use VSMALL, you'd end up with a huge number if alpha1 is indeed zero. To avoid problems the authors chose a small, but not too small value.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
#22 |
Rep Power: 15 ![]() |
But what if the alpha values that I am working with are also small? smaller than 0.001? then this hard-coded value will affect my results?
should I decrease this scalar value only few order of magnitudes then? |
#23 |
Rep Power: 10 ![]() |
I want to use bubblefoam solver but it prevents on my work, because of bubblefoam limitations.
BubbleFoam limitations The diameter of the particles constituting the dispersed phase is assumed to be consistent. Aggregation, breakage and coalescence phenomena are not accounted for. What is your suggestion? DO you know any solver uses Euler mixture model ? thank you |
#24 |
bubblefoam, equations, momentum |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
