FV patch problems when running pisoFoam in parallel
Old   July 14, 2010, 03:31
Default FV patch problems when running pisoFoam in parallel
Chris Butler
chrisb is on a distinguished road
Hi all,
I will begin this thread by stating that my experience in C++ is very limited. Despite this I have managed to modify Hrv's parabolic boundary condition (http://www.cfd-online.com/Forums/ope...tml#post190604) to perform a three dimensional version of the boundary condition. I run into trouble when I try and run the boundary condition in parallel:
[1] #0  Foam::error::printStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process.  Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption.  The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
  Local host:          system011 (PID 17805)
  MPI_COMM_WORLD rank: 1
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
 in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #1  Foam::sigFpe::sigFpeHandler(int) in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #2  __restore_rt at sigaction.c:0
[1] #3  Foam::rectilinearVelocityFvPatchVectorField::updateCoeffs() in "/provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so"
[1] #4  Foam::rectilinearVelocityFvPatchVectorField::rectilinearVelocityFvPatchVectorField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so"
[1] #5  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::rectilinearVelocityFvPatchVectorField>::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so"
[1] #6  Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[1] #7  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[1] #8  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[1] #9  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[1] #10  main in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[1] #11  __libc_start_main in "/lib64/libc.so.6"
[1] #12  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/usr/local/openfoam/1.6-gcc/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
[system011:17805] *** Process received signal ***
[system011:17805] Signal: Floating point exception (8)
[system011:17805] Signal code:  (-6)
[system011:17805] Failing at address: 0x2100000458d
[system011:17805] [ 0] /lib64/libc.so.6 [0x38464302d0]
[system011:17805] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3846430265]
[system011:17805] [ 2] /lib64/libc.so.6 [0x38464302d0]
[system011:17805] [ 3] /provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so(_ZN4Foam37rectilinearVelocityFvPatchVectorField12updateCoeffsEv+0x63e) [0x2aaab96eeaae]
[system011:17805] [ 4] /provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so(_ZN4Foam37rectilinearVelocityFvPatchVectorFieldC1ERKNS_7fvPatchERKNS_16DimensionedFieldINS_6VectorIdEENS_7volMeshEEERKNS_10dictionaryE+0x319) [0x2aaab96edf19]
[system011:17805] [ 5] /provider/project/user/OpenFOAM/1.6/lib/linux64GccDPOpt/librectilinearBC.so(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE31adddictionaryConstructorToTableINS_37rectilinearVelocityFvPatchVectorFieldEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x47) [0x2aaab96f4f77]
[system011:17805] [ 6] pisoFoam(_ZN4Foam12fvPatchFieldINS_6VectorIdEEE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIS2_NS_7volMeshEEERKNS_10dictionaryE+0x234) [0x422ea4]
[system011:17805] [ 7] pisoFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC1ERKNS_14fvBoundaryMeshERKNS_16DimensionedFieldIS2_S4_EERKNS_10dictionaryE+0xd3) [0x42cbc3]
[system011:17805] [ 8] pisoFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEE9readFieldERNS_7IstreamE+0xbe) [0x44158e]
[system011:17805] [ 9] pisoFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEC1ERKNS_8IOobjectERKNS_6fvMeshE+0xf3) [0x441be3]
[system011:17805] [10] pisoFoam [0x414a16]
[system011:17805] [11] /lib64/libc.so.6(__libc_start_main+0xf4) [0x384641d994]
[system011:17805] [12] pisoFoam(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0xd1) [0x413a09]
[system011:17805] *** End of error message ***
mpirun noticed that process rank 1 with PID 17805 on node system011 exited on signal 8 (Floating point exception).
Note:
This error happens on multiple systems.
The boundary condition is (currently) time independent so if I step forward once in serial I can successfully use the boundary condition by changing its type to fixedValue (nonuniform).
Error occurs under 1.6 & 1.7
I have forced (using simple decomposition) to ensure that the boundary is not split across processors. This does not help.
Any help would be much appreciated. Attached is a case directory with the boundary condition source included.
Cheers,
CB
chrisb is offline   Reply With Quote
Old   July 19, 2010, 02:12
Default Error found
Chris Butler
Just wanted to say I found the error. It was due to the parallel reduce within the bound box function was not enabled. With the bound box incorrect my boundary condition function created singular values.
CB
Old   March 21, 2011, 06:06
Jitao Liu
awacs is on a distinguished road
CB
Hi chrisb,
I am suffering a similar problem as you have mentioned above. Please give me some suggestions. Thanks in advance.
Here is the log:
| \\ / F ield | OpenFOAM Extend Project: Open source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
Build : 1.6-ext-1f09367282cf
Exec : conjugateRHCMFoam -parallel
Date : Mar 21 2011
Time : 17:59:50
Host : linux-szab
PID : 7621
Case : /home/of16ext/OpenFOAM/of16ext-1.6-ext/run/mycase/conjugateRHCMFoam/RHCM-electric/ERHCM-3D/ERHCM-3D-Parallel/polymer
nProcs : 4
Slaves :
3
linux-szab.7622
linux-szab.7623
linux-szab.7624
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : blocking
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
pcorr
solver PCG;
tolerance 1e-10;
relTol 0;
preconditioner DIC;
pd
solver PCG;
tolerance 1e-07;
relTol 0.05;
preconditioner DIC;
pdFinal
solver PCG;
tolerance 1e-07;
relTol 0;
preconditioner DIC;
T+T
solver smoothSolver;
smoother ILU;
nSweeps 3;
minIter 0;
maxIter 1000;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
tolerance 1e-06;
relTol 0;
preconditioner DILU;
T
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
Reading g
Reading transportProperties
Reading field pd
Reading field alpha1
Reading field U
Reading field T
Selecting incompressible transport model CrossArrhenius
Selecting incompressible transport model Newtonian
Calculating field g.h
Selecting turbulence model type laminar
Reading field Tsolid
Reading solid conductivity kT
time step continuity errors : sum local = 0.000183958, global = -0.000183958, cumulative = -0.000183958
DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 8.8536e-11, No Iterations 138
time step continuity errors : sum local = 1.62871e-14, global = 1.59112e-15, cumulative = -0.000183958
Courant Number mean: 7.7292e-05 max: 2.27224 velocity magnitude: 1.285
Starting time loop
Courant Number mean: 1.69873e-05 max: 0.499393 velocity magnitude: 1.285
deltaT = 0.00021978
Time = 0.00021978
MULES: Solving for alpha1
Liquid phase volume fraction = 2.02152e-05 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 3.90937e-05 Min(alpha1) = 0 Max(alpha1) = 1
DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.0188053, No Iterations 2
DICPCG: Solving for pd, Initial residual = 1.3167e-05, Final residual = 1.02047e-07, No Iterations 2
DICPCG: Solving for pd, Initial residual = 1.61937e-05, Final residual = 1.91329e-08, No Iterations 3
time step continuity errors : sum local = 4.82666e-08, global = -4.52055e-08, cumulative = -0.000184003
Solving the coupled energy equation
[linux-szab:07624] *** Process received signal ***
[linux-szab:07624] Signal: Floating point exception (8)
[linux-szab:07624] Signal code: (-6)
[linux-szab:07624] Failing at address: 0x3e800001dc8
[linux-szab:07624] [ 0] /lib64/libc.so.6 [0x7fa07e3ef6e0]
[linux-szab:07624] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7fa07e3ef645]
[linux-szab:07624] [ 2] /lib64/libc.so.6 [0x7fa07e3ef6e0]
[linux-szab:07624] [ 3] /home/of16ext/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoupledLduMatrix.so(_ZNK4Foam21coupledCholeskyP recon12preconditionERNS_10FieldFieldINS_5FieldEdEE RKS3_h+0x24c) [0x7fa081a3365c]
[linux-szab:07624] [ 4] /home/of16ext/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoupledLduMatrix.so(_ZNK4Foam18coupledIluSmooth er6smoothERNS_10FieldFieldINS_5FieldEdEERKS3_hi+0x 2e7) [0x7fa081a36167]
[linux-szab:07624] [ 5] /home/of16ext/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoupledLduMatrix.so(_ZNK4Foam19coupledSmoothSol ver5solveERNS_10FieldFieldINS_5FieldEdEERKS3_h+0x6 e0) [0x7fa081a3cc90]
[linux-szab:07624] [ 6] /home/of16ext/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libcoupledLduMatrix.so(_ZN4Foam15coupledFvMatrixId E5solveERKNS_10dictionaryE+0x60c) [0x7fa081a453dc]
[linux-szab:07624] [ 7] conjugateRHCMFoam [0x43d82d]
[linux-szab:07624] [ 8] conjugateRHCMFoam [0x427f41]
[linux-szab:07624] [ 9] /lib64/libc.so.6(__libc_start_main+0xe6) [0x7fa07e3db586]
[linux-szab:07624] [10] conjugateRHCMFoam [0x4209e9]
[linux-szab:07624] *** End of error message ***
mpirun noticed that process rank 3 with PID 7624 on node linux-szab exited on signal 8 (Floating point exception).
awacs is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 13:46
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 15:33
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
CFX - Parallel Problems CFX User CFX 0 November 1, 2004 19:12
