how to impose fixed value at a point (or region) during calculation ? |
February 25, 2012, 07:51 |
#21 | |
Santiago Marquez Damian
Rep Power: 24 |
Jorkolino,
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
February 27, 2012, 04:29 |
#22 |
Samuele Z
Rep Power: 19 |
Dear Santiago,
maybe you can help me, too. Do you know, by chance, how I can impose a certain value to some cells? I am using the solver buoyantSimpleFoam, running OF 2.0.1 I have tried - following some thread in this forum - to edit the source.. But the point is that nothing happens. I guess I am editing the wring files. Thanks, Samuele |
February 27, 2012, 09:00 |
#23 |
Olivier
Rep Power: 18 |
hello,
I am not sure this can help you, but from the 2.1 version, there is a new field source, in which you can set a value ( see explicitSetValue entry). Only few solver have this, but you can add to the buoyantSimpleFoam solver. regards, olivier |
February 27, 2012, 09:04 |
#24 |
Samuele Z
Rep Power: 19 |
Now I'll have a look..
This sounds great! Hope this is what I need. And I am looking forward to have the 2.1 version installed, then. Thanks a lot, Samuele |
February 28, 2012, 16:38 |
#25 |
Rep Power: 24 |
Samuele, I haven't explored OpenFOAM > 1.7.x so maybe your problem is already solved by the developers as Oliver told us. The way I was thinking about is:
http://openfoamwiki.net/index.php/Co...lockedCellFoam Regards.
February 29, 2012, 02:42 |
#26 |
Samuele Z
Rep Power: 19 |
That's good.
Thanks a lot. As soon as I get the OF 2.1, I'll try to solve this. Samuele. |
Torque Calculation at Arbitrary Point | Mojtaba | Main CFD Forum | 0 | February 14, 2009 00:58 |
Calculation torque on arbitrary point | Mojtaba | Main CFD Forum | 0 | February 9, 2009 00:08 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
Grid refinement with wall functions | Mark Render | Main CFD Forum | 8 | May 2, 2000 07:09 |
Non-uniform grid calculation | Aspens | Main CFD Forum | 1 | February 23, 2000 14:15 |
