June 28, 2010, 12:40 |
Flow through porous media
Rep Power: 16 |
Hello everybody,
I'm a newbie in OpenFOAM and have some problems with the implementation in OpenFOAM. As you can see in the title I'm examing flow through porous media using a new approach. Similar to the Darcy-Forchheimer-Equation I want to add a new term to rhs of the incompressible Navier-Stokes-Equation. As a basis I use the simple-solver in OpenFOAM. Now I'd like to change the implemented differential equation. The rhs looks in x-direction as follows: ... = dp/dx - a* u_x - b* (u_x)² .( a,b - scalar values) I tried a lot to implement it. But certainly I don't know the right commands. Can anybody help me? Many thanks in advance! |
June 28, 2010, 12:46 |
Stefan Herbert
Rep Power: 18 |
Hi marango,
you don't have to do anything on your own. Please have a look on rhoPorousSimpleFoam and its tutorials. This is a compressible solver, but you can use nearly the same commands for incompressible solvers. Regards, Stefan |
June 28, 2010, 14:15 |
Rep Power: 16 |
Thanks, Stefan, for your instant answer.
I already used the rhoPorousSimpleFoam-solver and implemented an incompressible version of this solver. Unfortunately the results were completely wrong. So I use a new approach, which also changes the lhs of the NSE. This is working right, but only the rhs makes problems. I also considered to use some commands from rhoPorousSimpleFoam, but either I couldn't find out what this command actually does or the mathematical background doesn't suite to my approach. |
no converge - for Low Re Porous media seepage flow | lee | CFX | 3 | August 31, 2007 02:12 |
Modeling porous media flow in prostar | Nirmal Kumar Pathak | Siemens | 8 | November 23, 2005 08:18 |
Flow Through Porous Media + Biochemical Reactions | Paresh Jain | CFX | 0 | September 20, 2003 06:06 |
How to simulate flow in porous media? | may song | Phoenics | 2 | August 29, 2002 00:10 |
Flow resistance of porous media | Desheng Kong | Main CFD Forum | 3 | December 19, 2000 12:07 |
