twoLiquidMixingFoam
Old   June 19, 2010, 11:28
Default twoLiquidMixingFoam
Maolong LIU
maolongliu is on a distinguished road
Hi, because the twoLiquidMixingFoam in OpenFoam is a transent solver. I was trying to change it to a steady state solver according to simpleFoam and twoLiquidMixingFoam.
Now the new solver can run successfully and it seems that the calculation result is correct. I compared u with experiment result and previous transient result.
But the problem is that there is a converge problem. After run a long time, pressure, k, epsilon etc. are all converged, but onlu u does not converge.
Time = 30575
DILUPBiCG: Solving for alpha1, Initial residual = 5.30999e-08, Final residual = 5.30999e-08, No Iterations 0
Phase 1 volume fraction = 0.500002 Min(alpha1) = 0 Max(alpha1) = 1
DILUPBiCG: Solving for Ux, Initial residual = 0.135853, Final residual = 1.4931e-08, No Iterations 6
DILUPBiCG: Solving for Uy, Initial residual = 0.0184276, Final residual = 1.39218e-08, No Iterations 5
GAMG: Solving for p_rgh, Initial residual = 3.33005e-07, Final residual = 3.33005e-07, No Iterations 0
time step continuity errors : sum local = 6.94663e-09, global = -1.76227e-11, cumulative = 2.20847e-08
DILUPBiCG: Solving for epsilon, Initial residual = 9.27893e-08, Final residual = 9.27893e-08, No Iterations 0
DILUPBiCG: Solving for k, Initial residual = 3.85187e-07, Final residual = 1.09717e-08, No Iterations 1
ExecutionTime = 22.01 s ClockTime = 22 s
Can anyone give me any advice? Thanks.
maolongliu is offline   Reply With Quote
Old   August 9, 2010, 06:20
Balkrishna Patankar
balkrishna is on a distinguished road
Do try changing the relaxation values ....
balkrishna is offline   Reply With Quote
Old   August 9, 2010, 06:31
Maolong LIU
Thank you for your reply. I modified the U equation
UEqn== -fvc::grad(p)
to
UEqn== fvc::reconstruct
according to the twoLiquidMixingFoam, and now this problem has been solved.
Now I am trying to speed up the convergence because my mesh number is really huge.
Now the procedure of this solver is
first solver U eqn
and then p eqn
and then alpha1 eqn.
Also I change the relax method of alpha eqn just like p eqn (restore alpha1 and relax alpha1 instead alpha1 eqn).
How do you think of it?
Thank you!
Old   August 9, 2010, 06:45
Balkrishna Patankar
thats a nice modification .... relaxing alpha1 after every loop does converge faster ....
I am working on something similar and facing a ver different problem ... pls do help ...
link to thread discussion here .: http://www.cfd-online.com/Forums/ope...tml#post270776
Old   August 9, 2010, 06:52
Maolong LIU
If you don't mind, please send me your code, so I can help to check.
Old   August 9, 2010, 06:56
Balkrishna Patankar
whats ur email ???
Old   August 9, 2010, 06:58
Maolong LIU
maolongliu@gmail.com
whats ur email ???
Old   August 11, 2010, 02:23
Balkrishna Patankar
In the twoLiquidMixingFoam what exactly is alpha1 ?? according to the o/p statement ,
it represents volume fraction , but how is the conservation equation formed on the basis of volume fraction ?
i mean conservation equation is :
d/dt(rho_fluid*mass_K) + divergence(rho_fluid*U*mass_K)= convection + source terms ....
where rho_fluid is density of the mixture ....
mass_K is the mass fraction of the Kth component ....
How is this written in terms of the volume fraction alpha ????
Old   August 11, 2010, 05:05
Balkrishna Patankar
got it ... the formulation is correct ....
Old   October 27, 2010, 22:26
phinallydone is on a distinguished road
Has anyone seen negative values for alpha1 in twoLiquidMixingFoam? If so, any idea what changes I can make to correct the problem? I'm runnig a simulation of a pipe with RE around 2000 that has water and a higher viscosity fluid (~25cP). Any help is appreciated.
Thanks in advance!
Phase 1 volume fraction = 0.000377962 Min(alpha1) = -2.37485 Max(alpha1) = 1
phinallydone is offline   Reply With Quote
Old   October 28, 2010, 03:39
Balkrishna Patankar
that is not possible .... ur solution will diverge ....
Old   October 28, 2010, 12:00
That's just it... it's not diverging. I've tried refining the mesh, relaxing alpha1, and adjustnig tols. Any ideas?
Old   November 12, 2012, 18:25
Kia
karasa03 is on a distinguished road
Hey Maolong,
Can you tell me how you changed the solver to steady state. I am working on a similar problem and my delta T is really small and will like to make it steady state to avoid the Courant number restriction.
karasa03 is offline   Reply With Quote
SimpleFoam with body force gravity alexice OpenFOAM Running, Solving & CFD 15 June 16, 2022 15:43
TwoLiquidMixingFoam shawn OpenFOAM Running, Solving & CFD 65 March 18, 2020 15:56
