Continuity equation in coupledFvMatrix
Old   June 8, 2010, 04:51
Default Continuity equation in coupledFvMatrix
BastiL
bastil is on a distinguished road
HI all,
I try to write a coupled solver that uses continuity equation. I tried to do it that way:
        coupledFvScalarMatrix coupledEqns(1);
        coupledEqns.set
            0,
            new volScalarField
                fvc::div(phi)
Does not seem to work that way. Do I need to convert to fvScalarMatrix? How? Thanks.
Regards Bastian
bastil is offline   Reply With Quote
Old   June 9, 2010, 05:07
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Just make it of type fvScalarMatrix:
coupledEqns.set
   0,
   new fvScalarMatrix
       fvm::ddt(rho)
       fvc::div(phi)
where phi = rho*U interpolated to the cell faces. You can't solve what you had previously because fvc::grad calculates the gradient explicitly; there is no variable to solve for!
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 9, 2010, 10:40
BastiL
Thanks Laurence,
since my code is steady-state and incompressible I do not really need fvm::ddt(rho). So I tried:
coupledEqns.set
   0,
   new fvScalarMatrix
       fvc::div(phi)
This throws an error:
Making dependency list for source file coupledFoam.C
SOURCE=coupledFoam.C ;  g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=1716 -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/coupledMatrix/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/transportModels -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/coupledFoam.o
In file included from coupledFoam.C:65:
coupledEqn.H: In function ‘int main(int, char**)’:
coupledEqn.H:14: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’
/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvMatrix.C:327: note: candidates are: Foam::fvMatrix<Type>::fvMatrix(Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double]
/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvMatrix.C:266: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double]
/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvMatrix.C:235: note:                 Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double]
/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/fvMatrix.C:188: note:                 Foam::fvMatrix<Type>::fvMatrix(Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double]
/opt/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude/initContinuityErrs.H:38: warning: unused variable ‘cumulativeContErr’
make: *** [Make/linux64GccDPOpt/coupledFoam.o] Error 1
I don't really understand why.
Old   June 9, 2010, 13:15
Hrvoje Jasak
Easy - you are trying to make a matrix and you are only giving it a field: fvc::div(phi).
That has no matrix coefficients - how do you expect to solve the system of equations that says
[0] * [x] = [b]
Hrv
Hrvoje Jasak
Old   June 9, 2010, 18:33
BastiL
[0] * [x] = [b]
Thanks Hrv,
that makes sence. I am not yet deep enough in it. So how is the correct formulation of the continuity equation?
Old   February 10, 2012, 08:40
mikeP is on a distinguished road
Hello Mr. Jasak,
This is interesting. Could you also explain this code (fvm::div(phi, U) == 0) in the matrix form, similar to what you have written before as [0] * [x] = [b] ?
All the best
mikeP is offline   Reply With Quote
Old   February 10, 2012, 10:24
another question - how is this possible? divergence of a scalar?
fvc::div(phi)
Old   October 13, 2014, 10:05
Default Hi
T.D. is on a distinguished road
fvm: (div,phi) == 0
Briefly explaining,
fvm: stands for implicit. A discretization in space is done first (via the FVM) and in time if necessary and all the coeffs. are placed in a matrix form [O], then the resultant of the discretization of the source terms are placed to the right hand side of the equation in a vector [S].where the unknowns are the velocity field vector components on the mesh.
All above, are such that [O]*[U] = [S] which is solved to find [U] vector field components.
For the scalar issue: you should see 4.4.5 in:
http://www.openfoam.org/docs/user/fvSchemes.php
Regards,
T.D.
T.D. is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
continuity equation Rafal Main CFD Forum 4 November 29, 2006 10:27
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
