FGM combustion model
Like Tree15Likes
Old   December 23, 2011, 17:02
Hannes Kröger
hannes is on a distinguished road
Hello guys,
the server at the university where I formerly worked at (janus) is out of service now. The repository has moved to another location which I don't know. And I also do not know about the access rules of this server (whether public access is possible).
I think Matthias Walter could clarify this. Matthias?
For now, I have packed up my latest working copy and put it here for download:
http://www.kroegeronline.net/exchang...Extensions.tgz
I don't know what the university has planned with the FGM code. I suppose currently nothing. I like the idea to put it in a sourceforge repository with write access for anyone interested and port it to OF 1.6-ext (which I currently use).
Hope that helps so far,
Hannes
cfdonline2mohsen likes this.
hannes is offline   Reply With Quote
Old   January 7, 2012, 16:18
Hannes Kröger
for those who are interested: I have created a git repository for the presumed-PDF, FGM and thickened-Flame combustion stuff at sourceforge.
You can clone it like this:
> cd $WM_PROJECT_INST_DIR
> git clone git://git.code.sf.net/p/ofca/code CombustionAddons
The repository contains the code modified to work with OF 1.6-ext. Up to now I have included the library and the solvers. It compiles but I have not tested anything yet. During the next time, I will add the chemistry table generation program and some examples for the solvers.
Regards, Hannes
babakflame likes this.
Old   February 13, 2012, 09:46
G.Maragkos is on a distinguished road
Thank you very much for your contribution Hannes. Any additional examples are also very welcome.
Regards,
Georgios
G.Maragkos is offline   Reply With Quote
Old   July 8, 2012, 07:50
Default flame let
  #24
Ali Lohrasbi Nichkoohi
nichkoohi is on a distinguished road
hello
thank you ,Hannes, because of your best code in OF(LTTRostockExtensions). would you please help me how do complie and install it in detail in openfoam 2.0.0 on ubuntu 10.10.
i am looking forward to hear from u.
best wishes
nichkoohi is offline   Reply With Quote
Old   July 12, 2012, 22:28
Default equilibrate gives floating point exception
  #25
ak
newOFuser is on a distinguished road
reposted as separate thread.
newOFuser is offline   Reply With Quote
Old   December 5, 2012, 04:31
Albrecht vBoetticher
vonboett is on a distinguished road
Hello Nichkoohi,
did you succeed using the LTTRostockExtensions in OF 2 ? It worked in OF 1.7. Using OF 2.2 I especially miss the dynamicMixedModel SGS for LES and the simpleGridFilter.
vonboett is offline   Reply With Quote
Old   December 5, 2012, 16:42
Hannes Kröger
I have not yet tried to port the stuff to anything above OF1.6-ext yet.
The former LTTRostockExtensions code is now maintained by Prof. Kornev's group at the modeling and simulation chair (LEMOS). They have started to move the LES stuff to OF2.1. You can find the link to their repository here:
http://www.lemos.uni-rostock.de/en/cfd-software/
Hope that helps..
Regards, Hannes
Old   December 8, 2012, 16:18
hi von
thanks for your reply. I could not install and compile that code on OF 2.0.0.
however do u have any suggestion for analysis of reacting flow with flamelet/LES modeling for diffusion flame?
thanks in advance
Old   December 10, 2012, 06:48
Hi Hannes,
Yes that helped, although I could not run it on Ubuntu 64bit and will try out on 32bit. I try to figure out the advantages of the lagrangian averaging at his thread: http://www.cfd-online.com/Forums/mai...tml#post396621
Old   January 6, 2013, 16:49
Default flamelet
  #30
hi von
i see the LTTRostockExtensions source code. i think it is same as libopensmoke.
did u see it? if yes what is your idea about it? i am going to convert the RAS on opensmoke to LES would u help me?
thank u in advance
Nichkoohi@yahoo.com
Old   January 7, 2013, 05:24
Hi nichkoohi,
I am afraid I can't help. I implemented LES into interDyMFoam some five or six years ago, when it was not part of the standard OF, and that worked quite well, I could reuse most of the code from lesInterFoam. But for libopensmoke I think you need to implement the whole filtering...
Old   January 8, 2013, 06:48
Default flamelet
  #32
thank u sir
Old   January 8, 2013, 13:27
Default flamelet
  #33
hi graham
is the lttrostoke same as cuoci libopensmoke code?
are u mean the lttrostoke can use the les/flamelet approaches
.thanks
Old   October 1, 2013, 11:25
Smile
  #34
Guilherme Sempionato
sempionato is on a distinguished road
Hi, Does anyone have made any progress in the compilation for 2.X OpenFOAM versions?
The work is hard but the benefits of these extensions worth works on this.
sempionato is offline   Reply With Quote
Old   December 8, 2013, 15:10
Hi, I having some problems with the pdfOodles compilling. Someone have compilled the libCombustionAddons for 1.6-extended and have tested the pdfOodles?
My interest is use this code with sprays.
Thanks.
Old   December 8, 2013, 15:27
Hannes Kröger
Hello Guilherme,
which problem do you have? Can you post some output or log?
Regards, Hannes
Old   December 9, 2013, 21:48
Originally Posted by hannes View Post
Hello Guilherme,
Regards, Hannes
Hi Hannes,
I have uploaded the stderr file:
http://www.fileswap.com/dl/ZtDXrcgmz/
Is this enough?
Thanks!
Old   December 10, 2013, 03:23
Hannes Kröger
Hello Guilherme,
looks like everything compiles but you get linker errors.
There is an "undefined reference to 'main'".
Is it possible that you built the library via "wmake" instead of "wmake libso"?
Regards, Hannes
Old   December 10, 2013, 03:45
Default who can send me the code LTTRostockExtensions
  #39
dongchao yang
dongchao yang is on a distinguished road
Hi, all
Is there any one using this code?
The links of LTTRostockExtensions above seem invalid now...
I'm intrested in FMG model, and want to get the code mentioned above.
Hope some one can help me.
yangdongchao@gmail.com
Best Regards
Dongchao
dongchao yang is offline   Reply With Quote
Old   June 5, 2014, 08:43
Likun
Likun is on a distinguished road
Send a message via Skype™ to Likun
Hi Foamers,
Has anyone succeed in compiling the FGM models in OF 2.3? I tried to do this, but there are some errors:
In file included from lnInclude/SIJPDFthermo.H:314,
from thermophysicalModels/compositionPdf/abstractProgressVariableThermo/abstractProgressVariableThermo.C:31:
lnInclude/SIJPDFthermo.C: In member function 'virtual void Foam::SIJPDFthermo<IndexDriver>::correct()':
lnInclude/SIJPDFthermo.C:1170: error: 'psi_' was not declared in this scope
lnInclude/SIJPDFthermo.C:1206: error: 'mu_' was not declared in this scope
lnInclude/SIJPDFthermo.C:1247: error: 'mu_' was not declared in this scope
lnInclude/SIJPDFthermo.C: In member function 'bool Foam::SIJPDFthermo<IndexDriver>::readPreIntegrated TableFromCache()':
lnInclude/SIJPDFthermo.C:1446: error: 'psi_' was not declared in this scope
lnInclude/SIJPDFthermo.C: In member function 'void Foam::SIJPDFthermo<IndexDriver>::writeCache() const':
lnInclude/SIJPDFthermo.C:1492: error: 'psi_' was not declared in this scope
can anybody help? Where are these errors come from? Is it because of the different OF version, because this CombustionAddons was previously using in OF1.7.
Many thanks in advance!
Cheers,
Likun
Likun is offline   Reply With Quote
Liquid rocket engine non-premixed combustion model Erik FLUENT 2 November 28, 2013 15:09
second and final question about flamelet combustion model AdidaKK CFX 0 October 17, 2009 08:25
Combustion Model for CAI/HCCI - AVL FIRE Patryk Main CFD Forum 0 July 24, 2009 17:43
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 10:16
combustion model Hennie van der Westhuizen Siemens 7 February 27, 2002 03:10
