nutRoughWallFunction and Surface Roughness Documented
Like Tree24Likes
Old   July 17, 2018, 04:37
Jurado
Jurado is on a distinguished road
Hello people,
Is there a reason why you do not use the "nutkAtmRoughWallFunction" that uses directly z0 ?
Jurado is offline   Reply With Quote
Old   July 19, 2018, 03:09
Michael Alletto
mAlletto will become famous soon enough
Can you provide a better description of your test case. Domain, inital and boundary conditions.
mAlletto is offline   Reply With Quote
Old   July 19, 2018, 04:29
Jurado
My question was just about the boundary condition on the ground for atmospheric boundary condition. Because I saw a lot of people using the sand grain relationship with ks and cs and that they had to convert their roughness length z0 into ks and cs.
While for I there is no need for that in as much as there is already a boundary condition for nut that take directly z0 parameter.
So I was wondering if something was wrong with it for people not using it or if people just didn't know it existed.
Old   July 12, 2021, 11:28
SUVECKSHYA
Shuveksha is on a distinguished road
How do you put that value or program for roughness in ansys?
The roughness that is inbuilt in cfd is which kind of roughness?
Shuveksha is offline   Reply With Quote
Old   January 6, 2024, 08:13
Marķa Rosales
MMRC is on a distinguished road
Hi Jurado,
I know its been years since your post. I'm somehow new to this ABL set-up, and I will rely on using atmNutWallFunc + omega/Epsilon atmEallFunc since they consider z0. I've seen too some foamers that uses standard wall BC's but there is a need (a must) to set z0 because this will help up to displace our wall level so we can mesh with y+ >> 30 & >> 300.
I do have an issue that pressure gradient running steady simpleFoam gaves me negative pressure at the inlet and 0 at outlet, using atmInlet BC's, but I think is because setting outlet to 0 and providing inlet velocity
Could you share the assumpation that you came to at that time?
MMRC is offline   Reply With Quote
Surface roughness in Flow-3d Marco FLOW-3D 3 June 3, 2018 03:15
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
